code 41 91
  • Thread starter Thread starter Shirley
  • Start date Start date Jul 21, 2007
Shirley
112
Phoenix, AZ
Jul 21, 2007
  • Jul 21, 2007
I've read the posts on code 41 and 91, and I have checked the vaccum lines for cracks, and have found none. (I do not have a vaccum pump) I just replaced both O2 sensors, and I am still getting the codes. Can someone explain to me where is the most likely place that a vaccum leak would occur. My gas mileage is crap, and I'm sure i have lost some power too. I took my a/c out,and the blower motor, but left the vac lines in tact. Could this be causing it?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 21, 2007
  • Jul 21, 2007
Finding vacuum leaks is a lot like going fishing. It requres some luck and some skill.
Use a vacuum gauge ($17 at most auto parts stores) to determine if a leak is present. You should see 16.5"-19" of vacuum at 650-725 RPM with a stock cam. More vacuum is better
Use a squirt can of motor oil to squirt around the mating surfaces of the manifold & TB. The oil will be sucked into the leaking area and the engine will change speed. Avoid using flammable substitutes for the oil such as propane or throttle body cleaner. Fire is an excellent hair removal agent and no eyebrows is not cool...
93 LX
3,081
Norwalk, CA.
Jul 22, 2007
  • Jul 22, 2007
check the PVC hose under the upper intake. Mine was bad, they are exposed to high heat and will get hard and crack
Engine Code 41 again
  • Creomod
  • Jul 7, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
Mcmahst
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
M
Progress Thread 1993 Ford Mustang 5.0 convertible stock manual - ODB Codes shows running lean
  • mcalvo
  • Feb 11, 2025
2K
Fox 5.0 Mustang Tech Feb 22, 2025
AeroCoupe
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Engine Ran my code reader and
  • Mindseye007
  • Aug 10, 2024
Fox 5.0 Mustang Tech Aug 19, 2024
Mindseye007
