So, what I am going to do tomorrow, cause just throwing this out there, and my theory could be totally wrong, but I'm thinking maybe what could be causing the lean to rich codes may not be that I am setting my fuel pressure wrong, checked again today and it was around 39 but seems to fluctuate a bit.
So I'm thinking the pump may not be pumping a consistent amount of fuel, or could be running hard or at high load. So when I had the idle set to 39psi I'm thinking it could be possible that at idle it was getting enough fuel but during the test when the engine rev's up, the pump may not be able to supply or keep up enough pressure but at idle it may have been fine. So I'm thinking that could cause the lean condition code, then when I increased pressure probably too high for idle, I'm think when the engine revs up to check whatever it is checking and because the pressure is turned up to high it could be fine and not reading lean anymore, but when it goes to normal and idle it is running to rich. This theory could be totally wrong and it could be completely different. So just to be sure and because I have the adjustable anyways, first thing tomorrow morning, (still on holidays for this week), I am going to drop the gas tank enough to install the new fuel pump and while I'm at it I will install a new fuel filter.
Then I will reset my base idle (no vacuum to 39psi), and will install the extra IAC motor I finally found (thought I had one)... and hopefully I will never see 41, 91, 12, 92 or 13 ever again.
Will let you guys know how it goes.. Still have one question for jricher.... or anyone who knows....
Where is the secondary power ground... because I replaced my fuel pump relay, checked to make sure pin 19 was installed right from the mass air conversion to the pink/black wire from the relay. And am still getting engine off code 96. So thinking if this secondary power ground isn't grounded right, maybe that could be the problem with code 96? Who knows!
Thanks again guys!!
We'll see how it goes tomorrow!!!! What a headach! I don't mind working on my car, under the hood or wiring, but I don't like working under the car, like on exhaust etc. Just don't enjoy it!
