code 42 too rich?
  • Thread starter Thread starter brycew
  • Start date Start date Apr 8, 2007
brycew
15
  • Apr 8, 2007
any help with this is appreciated. have already checked the distributor, timing, ignition coil and had the fuel pump filter and tank replaced 2 mths ago, vacuum test is good, and all the sparkplugs look great which is weird but it will stall after warmed up in park and try to drown itself in drive if im at a red light too long. get some intermitent pops on the right side of the headers when accelerating.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 8, 2007
  • Apr 8, 2007
Do a cylinder balace test to isolate stuck or leaking injectors.
Cylinder balance test:
Warm the car's engine up to normal operating temperature. Use a
jumper wire or paper clip to put the computer into test mode. Start
the engine and let it go through the normal diagnostic tests, then
quickly press the throttle to the floor. The engine RPM should exceed
2500 RPM's for a brief second. The engine RPM's will increase to about
1450-1600 RPM and hold steady. The engine will shut off power to each
injector, one at a time. When it has sequenced through all 8 injectors,
it will flash 9 for everything OK, or the number of the failing cylinder
such as 2 for cylinder #2. Quickly pressing the throttle again up to
2500 RPM’s will cause the test to re-run with smaller qualifying figures.
Do it a third time, and if the same cylinder shows up, the cylinder is
weak and isn’t putting out power like it should. See the Chilton’s Shop
manual for the complete test procedure
Here's the link to dump the computer codes with only a jumper wire
or paper clip and the check engine light, or test light or voltmeter.
I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections,
see http://www.actron.com/product_detail.php?pid=16153 for what a
typical hand scanner looks like. Normal retail price is about $30 or so
at Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes
or beeps.. Cost is $33.
Do a compression test on all the cylinders.
Take special note of any cylinder that shows up as weak in the cylinder
balance test. Low compression on one of these cylinders rules out the
injectors as being the most likely cause of the problem. Look at cylinders
that fail the cylinder balance test but have good compression. These
cylinders either have a bad injector, bad spark plug or spark plug wire.
Move the wire and then the spark plug to another cylinder and run the
cylinder balance test again. If it follows the moved wire or spark plug,
you have found the problem. If the same cylinder fails the test again,
the injector is bad. If different cylinders fail the cylinder balance test,
you have ignition problems or wiring problems in the 10 pin black &
white electrical connectors located by the EGR.
How to do a compression test:
Only use a compression tester with a screw in adapter for the spark
plug hole. The other type leaks too much to get an accurate reading.
Your local auto parts store may have a compression tester to rent.
If you do mechanic work on your own car on a regular basis, it would
be a good tool to add to your collection.
With the engine warmed up, remove all spark plugs and prop the
throttle wide open, crank the engine until it the gage reading stops
increasing. On a cold engine, it will be hard to tell what's good &
what's not. Some of the recent posts have numbers ranging from
140-170 psi. If the compression is low, squirt some oil in the cylinder
and do it again – if it comes up, the rings are worn. There should be
no more than 10% difference between cylinders. Use a blow down
leak test (puts compressed air inside cylinders) on cylinders that
have more than 10% difference.
See the link to my site for details on how to build your own blow
down type compression tester.
brycew
15
  • Apr 8, 2007
thanx
brycew
15
  • Apr 9, 2007
WOULDNT A FUEL PRESSURE TEST SHOW IF IT IS A LEAKING INJECTOR THE FUEL PRESSURE SHOULD DROP RIGHT?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 9, 2007
  • Apr 9, 2007
How bad do you want to find the problem? The paper clip costs less than a nickel and it only takes 10 minutes to do if you don't have to do the compression test. When you finish, you will know that the injectors are working good and aren't stuck open or leaking.
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
'04 V6 running rich excessively on both banks
  • 04DSGVert
  • Oct 26, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Oct 27, 2025
04DSGVert
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
