I recently had my neighbor do some work on my car to get it ready for the annual safety inspection. Namely replacing the front brake pads and turning both rotors to solve a vibration under braking issue I had and replacing the driver side parking/turn signal assembly . that was broken in an fender bender sometime ago.
He is a auto detailer by trade, but is also handy in turning a wrench...having also replaced the front wheel bearings and the driveshaft u-joints a few months ago for me. So I trust in his ability and general mechanical knowledge. The brake job went off smoothly, but he discovered that the mounting points for the parking/turn signal piece had been broken in the accident as well and needed to be replaced before he could finish the other repair. This required removing the headlights and the grille to get to the mounting bracket, which runs the whole width of the front end behind the headlights, etc. He also had to remove the driver's side fender to bend it back to closer to factory spec after said accident to make sure the opening lined up when he put the lens back into place.
He completed the work and got the car back to me in a couple of days, the mounting piece took 2 days to be shipped, and it looked great, considering how it had looked since the day I spun out on an icy overpass and brushed the concrete bridge wall. The braking under vibration was also gone, after already having the tires balanced and the front end aligned in an attempt to track down the cause in the previous months.
I took the car for inspection earlier this week and it passed with no problems. Drove it back and forth to work without drama. Went to start it to go to work yesterday and nothing. It turns over, but won't fire. I had to get to work so I had to leave it sitting in the garage while I took a friend's Jeep to work. Got home and hooked up the trusty Actron code scanner and got the aforementioned code 542 - Fuel Pump (FP) circuit open connection - Eletronic Control Assembly (ECA) to motor ground. I also noticed that the fuel pump does NOT prime when the key is turned to ON. I searched the forums and found an article that mentions being able to ground the fuel pump at the self-test connector in the engine compartment, which I did. I can hear a click near the radiator, which I'm guessing is the computer signalling the fuel pump relay to engage, but still no sound from the fuel pump out back.
It is possible that the fuel pump has really bitten the dust, the car does have close to 270,000 miles on the original (as far as I know) pump. If it is, then it defies all automotive break down odds....the car is in it's home garage and there is about 1/4 tank of gas in it at the moment, which is unheard of in this type of failure. I'm also thinking that a possiblity might be that I might have a loose ground to the fuel pump, if there happens to be one near the front clip...considering that my neighbor just did work in that area within the past week.
Does anyone happen to know where the ground(s) are in the front end of the 1994 Mustang GT that might be a possible cause to this problem? Like I said, it might be the actual fuel pump, but I'd like to rule out a possible quick fix instead of investing that much time into a fuel pump swap and have it not fix the problem anyway. Thanks for any help provided!
