This code has plagued me for too long. The clutch is depressed and the A/C is off (system is yanked out, switch is off). I've replaced the clutch safety switch and the neutral safety switch, and have no idea what else to do. Any ideas?
The car does it while running the KOEO test, and all I'm trying to do is get the MIL to turn off so I may pass smog. It all started with an AOD to T5 conversion. I have swapped the A9P for an A9L, the AOD harness for a T5 harness, replaced the clutch safety switch, and the neutral drive switch. And yes the trans is in Neutral when testing.
Thank you for the reply.
