Code 67
Code 67 - clutch not depressed (5 speed) or car not in neutral or park (auto) or A/C in On position when codes where dumped. Possible neutral safety switch or wiring problem. You can generally ignore this code, since it has no effect on engine performance.
The clutch was pressed down and I dont have ac anymore and the switch was off.I need to get rid of this code so I can run koer test.Any ideas on the 10 pin connectors?Do I need to get a new harness?
If you do the jumper wire method to dump the codes, you can do the KOEO Test without having to fix it.
As for the 10 pin connectors, I have cleaned them with WD40 and scraped the inside of the female pins with a jeweler's screwdriver. The male pins have a split running the lenght of the contact part. I used a larger jeweler's screwdriver to scrape the outside and then spread the split open slightly. This enlarges the pin's outer diameter.
See http://fordfuelinjection.com/index.php?p=6 for a diagram of what function goes to what pin.
