I pulled a 47 and 67 KOEO code. can only find out what code 47 is for KOER test. What does it mean for KOEO test? Also have a WOT miss above 3K. TFI tested good. When the puter is reset the miss goes away for about 2 days then it is back. That leads me to believe it's a puter controlled problem.(sensor, relay ect) if you roll into the throttle above 3k it's fine, just does it when I'm at WOT. when I bought the car(1 1/2 month ago) the wires into the WOT relay to cut the A/C off at WOT the wires were fried. I fixed the wires is there any way to test this relay? Any help and suggestions are greatly appreciated. Thanks.
