  • SN95 4.6L Mustang Tech
CODE HELP FAST!!!
  • Thread starter Thread starter SXYXC
  • Start date Start date Jul 19, 2007
SXYXC
77
  • Jul 19, 2007
ok so i just pulled up a couple codes of my car becuase its cel light was on this is that i got..
P1151 Lack of H02S-21 switch, sensor indicates lean and P1131 lack of H02s-11 switch, sensor indicates lean...
I havn't touched my O2 sensors all i have done is hit them as with my bolts with some PB blaster to make them easy to get off... what could be causing this?? and for both of them to read this?? what gives??
C
cooper
96
  • Jul 20, 2007
I wish you good luck, my car has been giving me the p 1131 code about 4-6 months now. i've changed the pasenger o2 sensor (up stream) I'll change the driver side tomorow or the next day to see if that helps. the car runs fine but , it stumbles and has a hesitation when its first started. A quick burnout seems to help if im frustrated!?
screamin gt
5 Year Member
Apr 9, 2007
393
central CT
Aug 23, 2007
  • Aug 23, 2007
I'm having that exact same issue. it only has that stumble when I first take off and then its perfectly fine like nothing happened.
had the p1151 code prior as well, cleaning the maf sensor fixed that one.
only thing I changed is cai and had the heads port polish and valve job.
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
  • Gulftown980x
  • Jul 29, 2026
squeak93
Engine Code 41 again
  • Creomod
  • Jul 7, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
Mcmahst
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
T
Looking for some help with 2006
  • thedudeillest
  • Mar 16, 2026
2005 - 2014 S-197 Mustang -General/Talk- Mar 20, 2026
