  • SN95 4.6L Mustang Tech
Code #P0441 anyone have this?????
  • Thread starter Thread starter 01mustanggt01
  • Start date Start date Sep 30, 2008
01mustanggt01
  • Sep 30, 2008
I have a 2001 mustang GT with the 4.6L, i am getting the engine light on and when i read the codes it comes up as a P0441 "Evaporative Emission Control System Incorrect Purge Flow". It doesn't run any different, i was told it might be the gas cap so i replaced it and erased the code and it came back a couple days later.
Has anyone else had this code and know what it takes to fix it?
Thanks
:SNSign:
H
HOOCBB
90
  • Sep 30, 2008
P044x codes are difficult to diagnose.
However, without actually looking at your car, I think your problem has to do with the Purge Solenoid and Purge Flow Sensor. it could be that the solenoid quit working or the flow sensor is not reading properly. Either way, if you replace one, replace both and replace the hoses connected to them at the same time.
I had a Ranger that threw P044x codes for about 2 years, I finally replaced the purge solenoid and flow sensor and associated hoses and the code went away.
If the problem was the gas cap or a cracked hose it would have thrown a code indicating a leak. A general leak would throw a P0440, a small leak would throw a P0442 (possibly a P0456) and a large leak would throw a P0455.
Given that your car threw a P0441, I would start with your purge valve and flow sensor.
  • Gulftown980x
  • Jul 29, 2026
squeak93
P
Resolved P0457 with intermittent fuel odor in cabin
  • PSKSAM2
  • Jun 3, 2025
SN95 4.6L Mustang Tech Jun 5, 2025
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
07 v6 4.0 wiring issue .In desperate need of help.
  • Staycstang
  • Sep 19, 2025
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech Sep 19, 2025
