Code P1131 & P1132 after headswap
97GTSTANG
852
Virginia
Update after headswap, car runs great and thanks for Willie from dirtydirtyracing. The mail tune he sent with the SCT made a world of difference. Thanks for all the help and answering all my questions.
Before the tune, i was pulling code 1131, after tune now its pulling 1132. I want to start first with the o2 sensor. The car was sitting for 8 months before the headswap, so maybe the 02sensor went bad. I was advised to start with the front 2 sensors.
Are these the correct ones? And i will need 2 correct? The car runs very well and i have read that usually when an 02 sensor is bad the car doesnt run very well at all. Any other suggestions? Thanks for all your help
NTK Performance Mustang Oxygen (O2) Sensor 22016 at AmericanMuscle.com - Free Shipping!
If you have long tubes, recommending staying with Ford O2 sensors.
What have you done to rule out the other "usual" causes for this DTC?
Both codes are for the same O2 sensor (Right front). So you could get by with replacing just the sensor called out.
Electrical:
Short to VPWR in harness or HO2S
Water in harness connector
Open/Shorted HO2S circuit
Corrosion or poor mating terminals and wiring
Damaged HO2S
Damaged PCM
Fuel System:
Excessive fuel pressure
Leaking/contaminated fuel injectors
Leaking fuel pressure regulator
Low fuel pressure or running out of fuel
Vapor recovery system
Induction System:
Air leaks after the MAF
Vacuum Leaks
PCV system
Improperly seated engine oil dipstick
EGR System:
Leaking gasket
Stuck EGR valve
Leaking diaphragm or EVR
Base Engine:
Oil overfill
Cam timing
Cylinder compression
Exhaust leaks before or near the HO2S(s)
on my 03 cobra ive had head issues 3 times...after repair i had o2 issues each time...which did fix problem each time as to 02 code problem,,
i also have long tubes,,i use the bosch 02 with longer harness...
