code problem
  • Thread starter Thread starter ponyboy762
  • Start date Start date Jul 18, 2004
P
ponyboy762
32
  • Jul 18, 2004
Here's the deal. I was pulling the codes from my 89 coupe, which is mostly stock. I ran the koeo test and pulled three codes,23,34,67. I looked them up and decided to run the koer test. I warmed the car up to normal running temp (about 180)and set the jumper wire the same as the koeo test, and when I restarted the car it sounded like it was testing but the check engine light didn't flash once. My question is did I do the test wrong or does this meen something is wrong?
HISSIN50
34
129
Jul 19, 2004
  • Jul 19, 2004
IIRC, the motor should be warm before doing any of the tests (i could be wrong on that - too many cars to remember).
i dont have a CEL, so i have not used a paperclip and dont know. a scanner for 25 bucks could streamline it for you - the instructions are pretty explicit.
my two cents. good luck.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 19, 2004
  • Jul 19, 2004
From your description, it seems that you did everything correctly.
The Key On Engine Off gets the codes in memory.
Running the engine with the jumper in will cause the CEL to quicky flash 4 and do the running self tests. It will dump only codes it finds with the Key ON Engine ON self test, it will not dump the stored memory codes. Only the codes it finds when it does the engine running self test will be displayed.
Code 23 - Throttle sensor out of range or throttle set too high - TPS needs to be reset to below .99 volts at idle. Keep in mind that when you turn the idle screw to set the idle speed, you change the TPS setting.
Code 34 EGR voltage above closed limit - Failed sensor, bad or missing signal ground, carbon between EGR pintle valve and seat holding the valve off its seat. Remove the EGR valve and clean it with carbon remover. Prior to re-installing see if you can blow air through the EGR valve by mouth. If you can, replace the EGR valve ($85-$95).
Code 67 - clutch not depressed (5 speed) or car not in neutral or park (auto) or air conditioning turned on. Possible neutral safety switch or wiring problem. You can generally ignore this code, since it has no effect on engine performance. It can affect the engine running self tests because of the extra drag on the engine.
P
ponyboy762
32
  • Jul 19, 2004
Does the fact that the CEL doesn't flash meanthat the computer is broken
StonysGT
220
winamac, Indiana
Jul 19, 2004
  • Jul 19, 2004
that is what i was thinking. i had a car one time where it brought up a lot of codes and evertime i fixed something another thing would come up. it ended up being the prom to the computer.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 19, 2004
  • Jul 19, 2004
The 4 flash is easy to miss.
The codes you got say that the computer is able to self diagnose & the fact that the engine runs would suggest that the computer is OK.
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
M
Progress Thread 1993 Ford Mustang 5.0 convertible stock manual - ODB Codes shows running lean
  • mcalvo
  • Feb 11, 2025
2K
Fox 5.0 Mustang Tech Feb 22, 2025
AeroCoupe
Engine 87 NA - Tune or no Tune needed?
  • R82148V
  • Sep 17, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
R82148V
