Code Readers Question
stang96blkgt
53
My car has been cutting out like there wasnt enough fuel going to the engine ...Seems to only do it once the car is warmed up. I pulled the code and got
1443: Evaporative Emission Control System Vaccum System, Purge Control solenoid or Vapor Management Valve Malfunction..
....Any help on where to start looking would be great, the car is a 96 GT 5spd,
Thanks GUYS
Thanks GUYS
The behaviour fits that code... The EECS consists of a management valve (above front wheel passenger side), and the charcoal canister/purge control solenoid (behind rear driver side wheel). The system is designed to catch fuel vapor, store it, and then burn it off when the engine is running. I would check the solenoid first because it is pretty much exposed to the elements whereas the VMV is protected by the body of the car and splash guard.
from alldata
HX - Evaporative Emission (EVAP) Monitor and System Notes
105636043
