Yeah, but then you only get the KOEO codes and not the KOER codes. If you have the cable, you can do the KOER codes with just one person.MysteryMachine said:I use the same one and so far haven't seen a need for the extra cable because you turn the key on then get out and push the button and the codes pop up. If your that lazy that you need to sit in your car to push a button you shouldn't be working on it lol
illwood said:Yeah, but then you only get the KOEO codes and not the KOER codes. If you have the cable, you can do the KOER codes with just one person.
MysteryMachine said:yeh the one JT is tallking about is from walmart. Its a great scanner showes the number af the code and has a book with them all listed. I use the same one and so far haven't seen a need for the extra cable because you turn the key on then get out and push the button and the codes pop up. If your that lazy that you need to sit in your car to push a button you shouldn't be working on it lol
Let me finish that for yaLabora said:Whatever you do don't waste your $$ on one that just beeps. My friend has one of those what a waste of time.
HISSIN50 said:Let me finish that for ya
.........unless you have a SD fox, in which case it is nice to hear the beeps while you are goosing wires, etc.
That was the reason I got mine - I would miss test light flashes, etc.
VibrantRedGT said:I have the Actron one I purchased from Pep Boys about 4 years ago. Just used it the other day when I was starting my car for the first time in 14 months. I think it was $34.95 back then.
Ive been looking for a post about it and havent seen one
Sorry RC, allow me to clarify. When you use the code scanner. If you just plug it in and turn the key to the run position as MysteryMachine suggested and get out of your car to read the code reader, that's only good for the KOEO (Key On Engine Off) codes. If you want to run the running test on sensors, you need the KOER (Key On Engine Running) codes that may require you to operate the accelerator cable at a specific time. I was suggesting that both would be easy if you had (or made) and extension cable to do this.94GTLaserRC said:illwood said:Yeah, but then you only get the KOEO codes and not the KOER codes. If you have the cable, you can do the KOER codes with just one person.
RC
