Codes 66 94 96
351GT
121
So with KOEO I got code 66 and 96. With KOER I got code 94
I have all of my smog equipment on and I have cats so why might I be getting code 94?
I did unplug my MAF the other day and my car has been sitting around for awhile so the MAF could be dirty and thats why I getting code 66.
96 im not sure
Codes 44 & 94 - AIR system inoperative - Air Injection. Check vacuum lines for leaks, & cracks.
Disconnect the big hose from smog pump: with the engine running you should feel air output. Reconnect
the smog pump hose & apply vacuum to the first vacuum controlled valve: Its purpose is to either dump
the pump's output to the atmosphere or pass it to the next valve. The next vacuum controlled valve
directs the air to either the cylinder heads when the engine is cold or to the catalytic converter when the
engine is warm. Disconnect the big hoses from the back side of the vacuum controlled valve and start the
engine. Apply vacuum to the valve and see if the airflow changes from one hose to the next.
The two electrical controlled vacuum valves mounted on the rear of the passenger side wheelwell turn the
acuum on & off under computer control. Check to see that both valves have +12 volts on the red wire.
Then ground the white/red wire and the first solenoid should open and pass vacuum. Do the same thing to
the light green/black wire on the second solenoid and it should open and pass vacuum.
Remember that the computer does not source power for any actuator or relay, but provides the ground
necessary to complete the circuit. That means one side of the circuit will always be hot, and the other side
will go to ground or below 1 volt as the computer switches on that circuit.
The computer provides the ground to complete the circuit to power the solenoid valve that turns the
vacuum on or off. The computer is located under the passenger side kick panel. Remove the kick panel &
the cover over the computer wiring connector pins. Check Pin 38 Solenoid valve #1 that provides vacuum
to the first Thermactor control valve for a switch from 12-14 volts to 1 volt or less. Do the same with pin
32 solenoid valve #2 that provides vacuum to the second Thermactor control valve. Starting the engine
with the computer jumpered to self test mode will cause all the actuators to toggle on and off. If after
doing this and you see no switching of the voltage on and off, you can start testing the wiring for shorts to
ground and broken wiring. An Ohm check to ground with the computer connector disconnected & the
solenoid valves disconnected should show open circuit between the pin 32 and ground and again on pin 38
and ground. In like manner, there should be less than 1 ohm between pin 32 and solenoid valve #2 and pin
38 & Solenoid valve #1.
If after checking the resistance of the wiring & you are sure that there are no wiring faults, start looking at the
solenoid valves. If you disconnect them, you can jumper power & ground to them to verify operation. Power &
ground supplied should turn on the vacuum flow, remove either one and the vacuum should stop flowing.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
See http://forums.stangnet.com/attachment.php?attachmentid=50636&d=1180923382 for a very nice drawing of the Thermactor Air System (smog pump) plumbing
If you have a catalytic converter H pipe, you need to fix these codes. If you don't, then don't worry about them
Some review of how it works...
The Thermactor air pump (smog pump) supplies air to the heads or catalytic converters. This air helps break down the excess HC (hydrocarbons) and CO (carbon monoxide). The air supplied to the catalytic converters helps create the catalytic reaction that changes the HC & CO into CO2 and water vapor. Catalytic converters on 5.0 Mustangs are designed to use the extra air provided by the smog pump. Without the extra air, the catalytic converters will clog and fail.
The Thermactor air pump draws air from an inlet filter in the front of the pump. The smog pump puts air into the heads when the engine is cold and then into the catalytic converters when it is warm. The Thermactor control valves serve to direct the flow. The first valve, TAB (Thermactor Air Bypass) or AM1 valve) either dumps air to the atmosphere or passes it on to the second valve. The second valve, TAD (Thermactor Air Diverter valve or AM2 valve) directs it to the heads or the catalytic converters. Check valves located after the TAB & TAD solenoids prevent hot exhaust gases from damaging the control valves or pump in case of a backfire. The air serves to help consume any unburned hydrocarbons by supplying extra oxygen to the catalytic process. The computer tells the Thermactor Air System to open the Bypass valve at WOT (wide open throttle) minimizing engine drag. This dumps the pump's output to the atmosphere, and reduces the parasitic drag caused by the smog pump to about 2-4 HP at WOT. The Bypass valve also opens during deceleration to reduce or prevent backfires.
attachment.php
Computer operation & control for the Thermactor Air System
Automobile computers use current sink technology. They do not source power to any relay, solenoid or actuator like the IAC, fuel pump relay, or fuel injectors. Instead the computer provides a ground path for the positive battery voltage to get back to the battery negative terminal. That flow of power from positive to negative is what provides the energy to make the IAC, fuel pump relay, or fuel injectors work. No ground provided by the computer, then the actuators and relays don't operate.
One side of the any relay/actuator/solenoid in the engine compartment will be connected to a red wire that has 12-14 volts anytime the ignition switch is in the run position. The other side will have 12-14 volts when the relay/actuator/solenoid isn't turned on. Once the computer turns on the clamp side, the voltage on the computer side of the wire will drop down to 1 volt or less.
In order to test the TAD/TAB solenoids, you need to ground the white/red wire on the TAB solenoid or the light green/black wire on the TAD solenoid.
For 94-95 cars: the colors are different. The White/Red wire (TAB control) is White/Orange (Pin 31 on the PCM). The Green/Black wire (TAD control) should be Brown (pin 34 at the PCM). Thanks to HISSIN50 for this tip.
To test the computer, you can use a test light across the TAB or TAD wiring connectors and dump the codes. When you dump the codes, the computer does a self test that toggles every relay/actuator/solenoid on and off. When this happens, the test light will flicker.
I need to know the year model of your car to give you the correct code 96 test path. The wiring changed in 91 and the wire colors are different.
So when I apply vacuum to the first vacuum controlled valve it didn't open. So is it defective? Also the electrical controlled vacuum valves on the passenger wheelwell they both have red wires and the other wire is yellow on one and yellow with a green strip. My car is a 93 so is that why the colors are different than u said or r these something else? Thanks
Posted via Mobile Device
