Codes 68 and 85???
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Ok... I dunno why it's coming up code 68, cause it's not used in the 5.0 Mustang... But 85.. These were pulled in KOEO. Any help with the Purge solenoid failure? Pulled the codes because of idle surging is getting worse.
Nick
Glad SN could help. Kind of like talkin to a shrink and diagnosing yourself with no input from the shrink. :D
Hey, JT... Can you direct me on how to set base idle correctly? My car should beable to idle at the stock idle speed just fine. The KOER test showed the IAC is working just fine (idled up all by itself). Joe was saying something about the iac not doing anything if the idle isn't set below 625 with the iac unplugged.. Any ideas? I hate this surging problem with all these new parts.
Nick
Like Joe mentioned, the IAC cant lower the idle, so the idle should be at 625 RPM (or near stalling, with a hot motor and no load) with no IAC input. That gives you your hot idle (no load) idle where you want it. Then the IAC adds additional air as needed for cold idle enrichment and load compensation.
Here is a decent synopsis of setting the idle for MAF (fox) cars.
Good luck Nick.
Well, I tried it and we'll see how she does... I drove it around and it seems to be good. At first I pulled the throttle stop screw out all the way and never put it back in, touching the throttle lol. I could feel it in the gas pedal driving it around... it felt like there was a catch in the cable, but it was just taking up the slack haahah. I adjusted it back to 700 ish and reconnected the IAC, and had my fiance drive it around because I know how to keep it from stalling. Having her drive it took that part out of the equation... She said it was fine... and she only stalled the car once hahahah. Thanks JT. You da man!
