Codes What do they mean?
WIPLSH
125
Scranton PA
Ok where to start. First my car is running like garbage(so what else is new) It is rought to start in the morning or when the engine is cold. When it starts I have to hit the gas to get it to idle. So I replaced the following.. The egr ( the thing inside was blown out from the supercharger now replaced the one way vacuum switch) and the ignition module. I also tighned up all my intak ebolts because the top was loose. It still does the same stuff idles rough and you can hear something poping in the intake(fuel)? I have no idea so I pulled the codes and got these... 51 ECT sensor(which could be bad because when I blew my heater hose it got soaked with Coolant) 85 CANP or ECA( is this the computer and if so is it bad) and 67? Can anyone help me?:bang:
Code 51 Engine Coolant Temperature (ECT) sensor signal is/was too high -
Possible bad ECT sensor, or wiring. Possible missing signal ground –
black/wire wire broken or bad connection. With the power off, measure the
resistance between the black/white wire and battery ground. You should see
less than 1 ohm. Check the same black /white wire on the TPS and MAP
sensor. More than 1 ohm there and the wire is probably broken in the harness
between the engine and the computer. The 10 pin connectors pass the
black/white wire back to the computer, and can cause problems.
Pin 7 on the computer - ECT signal in. at 176 degrees F it should be .80 volts
Voltages may be measured across the ECT by probing the connector from the rear.
Use care in doing it so that you don't damage the wiring or connector.
Here's the table :
68 degrees F = 3.02 v
86 degrees F = 2.62 v
104 degrees F = 2.16 v
122 degrees F = 1.72 v
140 degrees F = 1.35 v
158 degrees F = 1.04 v
176 degrees F = .80 v
194 degrees F = .61
Note that all resistance tests must be done with power off. Measuring resistance
with a circuit powered on will give false readings and possibly damage the meter.
Ohms measures at the computer with the computer disconnected, or at the sensor with
the sensor disconnected.
50 degrees F = 58.75 K ohms
68 degrees F = 37.30 K ohms
86 degrees F = 27.27 K ohms
104 degrees F = 16.15 K ohms
122 degrees F = 10.97 K ohms
140 degrees F = 7.60 K ohms
158 degrees F = 5.37 K ohms
176 degrees F = 3.84 K ohms
194 degrees F = 2.80 K ohms
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/
Code 67 - clutch not depressed (5 speed) or car not in neutral or park (auto) or A/C in On
position when codes where dumped. Possible neutral safety switch or wiring problem. This
code may prevent you from running the Key On Engine On tests. You can generally ignore
this code, since it has no effect on engine performance.
Code 85 - CANP solenoid - The Carbon Canister solenoid is inoperative. Check vacuum lines
for leaks and cracks. Check electrical wiring for loose connections, damaged wiring and
insulation. Check solenoid valve operation by grounding the gray/yellow wire to the solenoid
and blowing through it.
The computer provides the ground for the solenoid. The red wire to the solenoid is always
energized any time the ignition switch is in the run position.
