CODES
  • Thread starter Thread starter Brando5641
  • Start date Start date Sep 7, 2009
  • 3
  • 4
First Prev 3 of 4 Next Last
Brando5641
127
FT Gibson OK.
Sep 12, 2009
#41
  • Sep 12, 2009
  • #41
Ok i cant check voltage on the inj. but i got the #'s off of the puter.
B6B18
EEC-IV E6SF-12A650-M1B
SFI-SDI
also i noticed that some one has striped about an 1/8th of coating off of the inj. wires prob. checking for voltage.
Brando5641
127
FT Gibson OK.
Sep 12, 2009
#42
  • Sep 12, 2009
  • #42
It is a V8 puter. It has VM1 in the upper right and that is a good #
Ford Fuel Injection EEC Program Codes about 3/4 of the way down.
I think the computer is crap.
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Sep 12, 2009
#43
  • Sep 12, 2009
  • #43
Its fubar more than likely.
And I dont trust the ECM numbers on the case either. Ive seen ECM's from smaller company's that just reused an old case from whatever.
Still think its an ECM from a 6 cylinder though. I could be wrong. Either way Id find another one. May as well get one thats Mass Air and do the Conversion on your harness.
Brando5641
127
FT Gibson OK.
Sep 12, 2009
#44
  • Sep 12, 2009
  • #44
Im with you on that.
Also is the TPS supposed to be an adj one? Mine doesn't have the oblong hole to adj. it
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Sep 12, 2009
#45
  • Sep 12, 2009
  • #45
No the TPS doesnt come with slots in it.
Like I said code 71 is not a Mustang code......Its an EEC-IV code, just not for a mustang ECM. Thats why I dont believe the ECM numbers
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 13, 2009
#46
  • Sep 13, 2009
  • #46
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
The V8 computers will post a 4 when the engine is running and computer is jumpered into diagnostic mode. If you are looking to post an 8, it will never happen. A 6 cylinder computer would post a 3 under the same circumstance.
Brando5641
127
FT Gibson OK.
Sep 14, 2009
#47
  • Sep 14, 2009
  • #47
Ok i got a new computer coming but i noticed today that the car runs perfect when it is still cold. It is still idling high but for about 2 min it is a beast, then it just goes back to normal 4banger mode.
Brando5641
127
FT Gibson OK.
Sep 15, 2009
#48
  • Sep 15, 2009
  • #48
pulled codes with a light and i got same thing.
I bought a new IAC today put it on and it did nothing for the high idle / surging. But i did notice that when you start it up and take off it runs perfect, but after a few seconds you will feel the car stumble and it looses all power. This makes it realy weird, you can turn the car off for a few seconds then start it back up and it is a beast for a few seconds then it looses power again. I am starting to think it is a loose connection b/c if i kill it start it back up rev it and dump the clutch it will start to spin then die for about a 1/4 of a sec then come back, or when you do a hard 1-2 shift it will cut out and after it cuts out it looses power.
Does this help any?
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Sep 15, 2009
#49
  • Sep 15, 2009
  • #49
Check the 10 pin connectors behind the Intake. Take them loose, clean them with some contact cleaner, try very carefully to tighten the PINs up in the connector for a good connection.
Brando5641
127
FT Gibson OK.
Sep 16, 2009
#50
  • Sep 16, 2009
  • #50
I already did that but i will do it again to make sure. But what gets me is it runs fine for a sec when you restart it.
Also will a 87 puter work in a 86?
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Sep 16, 2009
#51
  • Sep 16, 2009
  • #51
Posted via Mobile Device
87 will work. As long as its setup for your type of vehicle(Auto or Manual)
You may also wanna open the ECM up and check the 3 blue electrolytic capacitors on the board. If they are leaking on the board, it will cause all sorts of problems.
Brando5641
127
FT Gibson OK.
Sep 16, 2009
#52
  • Sep 16, 2009
  • #52
Ok new computer is in car and it is ALOT better on power but i got some new codes. 53 and 63, bolth of those #'s are pointing at the TPS. The car will not idle when it is cold and is surging VERY bad and i have a high idle.
I checked the TPS voltage and i got
1.07 at idle
4.50 at WOT
4.98 Total
Shouldn't my WOT voltage be at 4.98?
If i pull the plug on the new IAC it only drops the rpms about 150. If i pull the plug on the TPS it still surges its just more slugish,and i pulled the vac. to the egr and that did nothing (there is no vac. to it by the way).
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Sep 16, 2009
#53
  • Sep 16, 2009
  • #53
Those are conflicting codes. So this has to be the KOEO test codes correct?
Brando5641
127
FT Gibson OK.
Sep 16, 2009
#54
  • Sep 16, 2009
  • #54
Right.
I tested the wiring for the eger,map,and tps by the o meter like JR says to and it looks good to me.
.004 EGR
.004 TPS
.004 MAp
TO GROUND.
MAP-TPS .001
EGR-TPS .001
BLACK WIRE TO BLACK WIRE
Brando5641
127
FT Gibson OK.
Sep 16, 2009
#55
  • Sep 16, 2009
  • #55
Engine running i got 91 and 13 with a test light.
13 is Idle is to low???? how is that possible? It idle's at 1500 rpms!
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 16, 2009
#56
  • Sep 16, 2009
  • #56
Code 13 Key on Engine running - Idle Speed Control motor or Air Bypass not controlling idle properly (generally idle too high)
If your idle is above 725 RPM, the computer will set this code. Normal idle speed is 650-725 RPM. Higher than that may mean that you have a vacuum leak or someone has mechanically set the idle speed by use of the idle speed screw. This effectively disables to computer’s ability to control idle speed.
Possible vacuum leak, that would account for the 91 code and the high idle.
Brando5641
127
FT Gibson OK.
Sep 16, 2009
#57
  • Sep 16, 2009
  • #57
CHECKING THE IAC MOTOR AND WIRING
(engine off)
12.25 volts @ red wire
.02 w/lt blue
.10 om's across prongs on IAC
The w/ltb wire has a problem, on the surging idle checklist is says i should have " less than 12v but more than .5" and if less than that there is a short.
This was with the engine off, it does not say to have the engine running.
Brando5641
127
FT Gibson OK.
Sep 16, 2009
#58
  • Sep 16, 2009
  • #58
Jr i just put a new upper intake gasket and new vac hoses, but i know that doesn't rule out a vac. leak. Also the idle screw is all the way in but it has been like that sence i got the car and i didnt want to just drop the idle that way and just be band aid fixing it. Is it not normal for the screw to be all the way in?
I will change the lower intake gaskets this weekend and see what happens.
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Sep 16, 2009
#59
  • Sep 16, 2009
  • #59
No the screw shouldnt be all the way in.
Need to concentrate on the Lean code.
Brando5641
127
FT Gibson OK.
Sep 16, 2009
#60
  • Sep 16, 2009
  • #60
what do i need to do?
  • 3
  • 4
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
J
Engine Running like crap :(
  • justadude07
  • Sep 27, 2025
Fox 5.0 Mustang Tech Oct 19, 2025
DadLife0724
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
'04 V6 running rich excessively on both banks
  • 04DSGVert
  • Oct 26, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Oct 27, 2025
04DSGVert
