Coil Over Kit
  • Thread starter Thread starter Fri Guy
  • Start date Start date Aug 24, 2022
First Prev 2 of 2
F
Fri Guy
435
259
83
Aug 26, 2022
#21
  • Aug 26, 2022
  • #21
I have some adjustable lower control arms on the car already. I think the poly isolators I used on the H&R Super Sport coils didn't help with the stance I'm getting. I thought about removing the isolators but not sure how it would work with metal on metal.
bird_dog0347
still married haven't seen testicles in years
2,328
2,084
174
Little Elm, TX
Aug 26, 2022
#22
  • Aug 26, 2022
  • #22
It's been a while since I messed with conventional spring setup on the rear, but did you make sure the spring pig tail is setup correctly on the perch?
AeroCoupe
6,259
4,341
183
Claremore, OK
Aug 26, 2022
#23
  • Aug 26, 2022
  • #23
Don't remove the isolators as it will make noise. Remember, the lower you go the higher the odds you will get bump steer.
Don't they point to the driver side? Been years for me as well. Just search it.
F
Fri Guy
435
259
83
Aug 26, 2022
#24
  • Aug 26, 2022
  • #24
Yeah they are correctly installed. From my understanding the poly isolators raise the car up some, should have reused the stock rubber ones.
AeroCoupe
6,259
4,341
183
Claremore, OK
Aug 26, 2022
#25
  • Aug 26, 2022
  • #25
They will raise it compare to the worn out / busted / missing stock ones but dimensionally they are the same as new stock ones or at least the ones from MM on my Coupe are. Realize the ones on my Coupe from MM are over 15 years old.
Reactions: Fri Guy
Mustang5L5
Mod Dude
Feb 18, 2001
43,392
18,135
224
Massachusetts
Aug 26, 2022
#26
  • Aug 26, 2022
  • #26
Fri Guy said:
Damn, the rear is the main reason I want to go with coil overs. Needs some fine tuning to get the ride height that I'm after.
I use the Mm adjustable rear control arms. I use that dial in the height with the front coil overs
Reactions: General karthief and Fri Guy
First Prev 2 of 2
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
D
Brake & Suspension Rebuild
  • DuluthFoxbody
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 14, 2026
Rdub6
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
Bilstein shocks
  • cnorman31
  • Dec 21, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 24, 2024
limp
D
sad day
  • davecobra2
  • Jul 13, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jul 22, 2026
davecobra2
D
