Coil relocation
  • Thread starter Thread starter TrophyHead
  • Start date Start date May 8, 2010
TrophyHead
1,195
11
49
PA
May 8, 2010
  • May 8, 2010
Hi, friends.
I've seen alot of pics of guys running there igntion coil to the left side of there engine bay.
Should I tie into my TFI wiring? From the TMoss wiring diagram looks like I could grab the hot right there for coil connector. Not sure where to grab neutral?...fuel connectors...ground battery lug on engine?
Thanks for any advice.
:edit: Relocation
HISSIN50
34
129
May 8, 2010
  • May 8, 2010
The ground has to come from the TFI. It is modulated.
Accessory power can come from an ignition wire that is hot during *cranking* and running.
TrophyHead
1,195
11
49
PA
May 10, 2010
  • May 10, 2010
Thanks HISSIN
For future searchs....Pin 4 on TFI and what hissin said will work.
HISSIN50
34
129
May 10, 2010
  • May 10, 2010
IIRC Pin 4 is the crank (only) signal.
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
May 11, 2010
  • May 11, 2010
Thats PIN 3 on the TFI JT.
HISSIN50
34
129
May 11, 2010
  • May 11, 2010
Here we go again. This diagram from Joe's (S&2B's) site is the one most people here reference, so it's the one I reference.
Pin 4 on this diagram is a crank signal.
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
May 11, 2010
  • May 11, 2010
I still dont understand the reason to count backwards as you go down the connector. If you start a list if things, you always start at the top with 1 and then go down and the numbers increase.
HISSIN50
34
129
May 11, 2010
  • May 11, 2010
I hear you Joe. That confused me the first time too.
I think I will either just have to say "from the top of the TFI, it's the Xth wire down" or just post the diagram and note which number it is. We just gotta be sure people are on the same page.
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
  • dan50
  • Jul 18, 2026
dan50
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
A
Resolved 03 GT Parasitic Draw Fuse 26 (PCM)
  • Antrix
  • Mar 22, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 24, 2025
89ripper
Progress Thread Giving an abandoned 88 GT project a new chance at life
  • jaketractor
  • Jan 9, 2025
2K
Fox 5.0 Mustang Tech Jul 20, 2025
