Coil Spring Adjusters?
  • Thread starter Thread starter [BlackDiamond]
  • Start date Start date Nov 11, 2005
[BlackDiamond]
119
  • Nov 11, 2005
Hey all.
I was browsing through Lordco and found this COIL SPRING ADJUSTER KIT. On the box it said "Lift or Lower your vehicle by 1/5 - 2"
Has anybody ever tried one of these? Im considering lowering my car about 1 inch only and instead of spending the 150-200 on springs I thought this may be a good solution at $19.99
hehe
Can anybody give me more information about this? Worth it or Junk?? Any side-effects / downsides of installing something like this on my springs?
Thanks
AP1995V6
547
Oxford, MS
Nov 11, 2005
  • Nov 11, 2005
I'm assuming that's an adjustment tool for cars with coil-overs; since they are adjustable. Depending where you get them, they're around $900-1000 for all around with new shocks/struts and hypercoil springs.
[BlackDiamond]
119
  • Nov 12, 2005
So this woudnt work with a stock 2001 Mustang? As far as I could understand, this is a clamp that COMPRESSES the suspension spring, thus lowering the car.
AP1995V6
547
Oxford, MS
Nov 12, 2005
  • Nov 12, 2005
I wouldn't trust it has far I could throw it, if it's a clamp that compresses the spring to lower the ride height. You would probably be better off taking a dye grinder to your springs.
03v6
14
Georgia
Nov 17, 2005
  • Nov 17, 2005
If they are just clamps.. two per spring.. a bolt w/ two ring type things.. it will mess your car up.. trust me go with the springs... i had them for about six monts.
Problems
1) My exhaust began hitting the axle.. so i got my muffler guy to rebuild it under the axle.
2) One of the clamps began rubbing against a brake line, and ended up putting a hole in it- lost the brakes 120 dollar part from ford and 100 installation.
3) Noise- every time i hit a bump, they would hit the body in some spot, way, or form. Even though when my father and i installed them.. we made sure they wouldn't hit anything... they still did, they would twist their way around the spring at their own will.
4) All noises make the ride seem much stiffer.
5) Two times on the back right they both went to one side of the spring and basically bent the spring hard to one side....i hit a hard bump turning into a car dealership and the spring popped out of place, i rode to the local tire shop, where some friends work, and got them to force the wheel off (due to the spring holding it on) and fix it.
6) those friends didn't put the clamp back on rite so i ended up loosing one clamp off of the back right spring, which causes another noise.
7) I put roush springs on, so then my exhaust was hitting the axle again so I got it rebuilt over the axle... agian.
8) And all of the times i jacked my car up and forced a clamp back onto the opposit side of the spring.
I have had no problems since i got my roushes installed..... trust me .. you get what you pay for.
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Monday at 2:12 PM
mattcrp1
M
A definitive answer to the question of how much height Energy Suspension isolators add
  • 2000xp8
  • May 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2025
2000xp8
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Yesterday at 6:22 PM
JH96GT
M
  • mnky99
  • Sep 5, 2025
mnky99
M
