coil springs
  • Thread starter Thread starter cptam1
  • Start date Start date Feb 14, 2006
C
cptam1
32
Ft Riley Ks
Feb 14, 2006
  • Feb 14, 2006
I have a 351M/400 engine in my stang. I need heavy duty springs and shocks where do i get them. No one has HEAVY DUTY.
1Bad67
52
  • Feb 14, 2006
You can get 720 lb springs from Maier Racing or 750 lb Grab-a-Tracs from Mustangs Plus. They are pretty stiff. 620's would be fine with any good shock Koni, Spax etc.
LMan
1,246
Mom's basement
Feb 15, 2006
  • Feb 15, 2006
How did you end up with an oddball like a 351M/400 in your Mustang? *yick*
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Feb 15, 2006
  • Feb 15, 2006
NPD lists all kinds of HD springs; they were usually used on big block, a/c equipped cars with sport handling package.
F
ForceFed70
That's why they call it "dope"
4,818
BC Canada
Feb 15, 2006
  • Feb 15, 2006
You don't need anything all that heavy duty.
Have you looked into how much the 351M weighs compared to a 351C or a 428?
65shlbycln
1,266
Atlanta
Feb 15, 2006
  • Feb 15, 2006
I had grabatraks, and they worked well. Try those out.
C
cptam1
32
Ft Riley Ks
Feb 17, 2006
  • Feb 17, 2006
The person who owned the car gave it to his son, who F^&%* it all up. pulled the engine and took an engine and tranny out of a TRUCK to race it. Theorizing that if the engine in a heavy truck can go fast. In a light mustang light speed is attainable.
J
John Z
581
Morgantown WV
Feb 17, 2006
  • Feb 17, 2006
Some interesting info about the 351M
http://www.projectbronco.com/History/history_of_the_ford_351m.htm
By the way, the 351M and 351C weigh about 550 lbs. The 302 is about 470, 351 W about 510, and the big blocks are in the 640 - 680 range. Springs designed for any 351 would be ok.
Engine Which fan clutch ?
  • AnthonyA1234
  • Jun 22, 2026
Fox 5.0 Mustang Tech Sep 19, 2026
Mustang5L5
Engine Standard or hi flow water pump?
  • AnthonyA1234
  • Sep 28, 2026
Fox 5.0 Mustang Tech Oct 9, 2026
2000xp8
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Motor mounts question
  • djj62478
  • Mar 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 13, 2026
nickyb
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
