  • SN95 4.6L Mustang Tech
Coilovers question?
  • Thread starter Thread starter jivepepper
  • Start date Start date Sep 20, 2007
jivepepper
776
Under a Sombrero. in WV.
Sep 20, 2007
  • Sep 20, 2007
I'm getting ready to install a tubular K-member, A-Arms, and front coilovers along with 4 bolt caster camber plates.
My question is do I just adjust the coilovers to a stock height since the rear is still stock? Or should I lower it in the front just a little? Would it be best to take a measurement before disassembling the k-member and try to match that?
Thanks.
BennyBlown2v
1,233
Carmel, INdiana
Sep 20, 2007
  • Sep 20, 2007
Yes, take measurements. Also, to get proper ride height, measure at the pinch weld seem on the lower rocker, not the center of the fender (this is a much more accurate place to measure true ride height). If you just wanna do drag racing, keep the front stock height if the rear is stock.
jivepepper
776
Sep 20, 2007
  • Sep 20, 2007
I was going to measure from bottom of the car right behind the front tire to the ground.
O
Back in a Fox
  • Osorio299
  • Jul 24, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 25, 2026
gkomo
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
Fox Alignment Suggestions
  • PonyGTrider
  • Jul 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 13, 2025
PonyGTrider
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
