  • 1994 - 1995 Specific Tech
Colant leak?
  • Thread starter Thread starter SMOKEDYA
  • Start date Start date Dec 4, 2005
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Dec 4, 2005
  • Dec 4, 2005
So on our 95's if your looking at the front on the engine from the front of the car, i see that there is coolant in the pockets behind the timming cover. Any ideas on where it could be leaking from? You cant see it driping tho? peace
john
wicked95gt
25
  • Dec 4, 2005
Check the thermostat housing because I just had that same problem on my car.
Stangfreak95
add a 4
3,571
In your sister. If none, your mom
Dec 4, 2005
  • Dec 4, 2005
Yep most likely the thermostat. Or maybe a leak from the top of the waterpump but I dont think so. I had the same problem last year.
CManT1914
3,172
Killeen, Texas
Dec 4, 2005
  • Dec 4, 2005
Lower intake to block gasket might be shot. Have you had the intake off for any reason? Mine is leaking there worse and worse everyday, I need to pull the intake off and reseal it.
juiced_94gt
1,143
Southern California
Dec 4, 2005
  • Dec 4, 2005
COULD be the intake but it's probably the t-stat housing unless you have removed the intake for any reason?
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Dec 4, 2005
  • Dec 4, 2005
I did put a trick flow upper and lower on but i cant think if it was like this before also? Also put a new thermostaet gasket as well with the lower. If the lower was leaking that would a vacum leak form hell wouldnt it? peace
john
CManT1914
3,172
Killeen, Texas
Dec 4, 2005
  • Dec 4, 2005
john
Yes sir that could be a vacuum leak. I'd dry that area off real good, then keep a CLOSE eye on it for the next day or two, and see where it starts to come from.
RIO5.0
6,892
N.H.
Dec 4, 2005
  • Dec 4, 2005
Mine has a bigtime leak right there at the thermo...Have you tried to re-tighten the bolts??? Just go easy as it Alum...
sade04
97
Lansdale, PA
Dec 5, 2005
  • Dec 5, 2005
mine was leaking and it turned out to be a little pin hole in the bypass hose, you might have the same problem?
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Dec 5, 2005
#10
  • Dec 5, 2005
  • #10
Good points guy's and thanks for all the suggestion's! If it were a intake leak it would run like crapola ? So i wont do anything if it is a leaking intake till i do my AFR'S in a couple months. And the car runs fine so i dont think it's an intake leak. peace
john
281pony
2,681
Oly, WA
Dec 5, 2005
#11
  • Dec 5, 2005
  • #11
most likely its the thermostat.
dont use the cheap thin paper gasket. make a template of it onto a piece of cork. then cut it out, coat both sides in rtv. put it on.
havent ever had it leak again after using cork gaskets.
RIO5.0
6,892
N.H.
Dec 5, 2005
#12
  • Dec 5, 2005
  • #12
Hmmm...Think I'll give the cork
RTV trick a shot this time round...Mines the FRPP chrome one and there known to leak...amnit:
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Dec 6, 2005
#13
  • Dec 6, 2005
  • #13
The local machn. heretold me about this stuff caled "the great stuff" it's some awsome stuff but it is a little spendy at $15 bucks a tube! peace
john
Black95GTS
1,644
Marlborough, MA
Dec 6, 2005
#14
  • Dec 6, 2005
  • #14
john
Don't use Great Stuff on a car. Its an insulating foam and I don't think its appropriate. There are also different kinds of this stuff and I KNOW some kinds of it will eat away at metal. I know this because at the power plant where I work they used it to seal in some wiring and we couldn't figure out where we were getting faults... turned out the great stuff ate away at the wire insulation and at wires themselves.
A T stat gasket is like 2 bucks at NAPA. I had the exact same problem as you because I overtorqued the bolts so bad on my first t-stat change that I actually screwed the bolt INTO the housing. Yes, I'm an idiot. The housing had a hair line crack in it and I had to replace it... NAPA also has replacement housings for 9 bucks, and they are steel, not aluminum.
Adam
xkuntrycowboyx
281
Marion, Indiana
Dec 6, 2005
#15
  • Dec 6, 2005
  • #15
For reference, and since my cars at home and im at college, can i get a pic??? anyone, of what we're talkin bout. Just following here to learn, id appreciate it, thanks guys
Black95GTS
1,644
Marlborough, MA
Dec 6, 2005
#16
  • Dec 6, 2005
  • #16
http://www.stangnet.com/tech/thermostat.html
first read that
the parts we're talking about it are:
http://www.napaonline.com/masterpag...K&PartNumber=6051080&Description=Water+Outlet
NAPA calls it a Water Outlet.. its the piece that juts out and is attached to the lower intake.
adam
1994Vib.RedGT
585
Denver, CO
Dec 6, 2005
#17
  • Dec 6, 2005
  • #17
I had a bad coolant leak a few months ago, and it was where the water goes into and out of the block at the water pump, so I had to get a new timing cover gasket, you might look into that.
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Oct 4, 2026
manicmechanic007
J
Engine Coolant leak from oil filter
  • jr273
  • Mar 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 31, 2026
squeak93
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
P
Engine Mysterious coolant leak at back of engine
  • palerider94
  • Jan 18, 2026
Fox 5.0 Mustang Tech Jan 19, 2026
AeroCoupe
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
