sandman0023 said:I have a 1989 GT and am stuck between a Cold-Air intake or a MAF system? Which one is better?
Swarzkopf said:Get both.
The MAF will result in a bigger horsepower gain: the sensor itself will give you the biggest horsepower gain, rather than the larger tube size. The sensor is calibrated to give you a better, more accurate reading resulting in a superior air/fuel ratio in most performance MAFs. The difference between my 95 when it was running the stock MAF versus the Pro-M 75mm was amazing.
Get a Pro-M 75mm MAF and a $50 ebay cold air kit and you'll be good to go.
i beg to differ a maf with adjustable FPR and the right injectors will make a noticable difference.....and a non show cold air will only help that much more.jb89coupe said:You mean an aftermarket mass air sensor? Neither one is really going to do much on a stock engine. I say get a k/n panel filter, remove your air silencer, and save your money for something else down the road. If you really want one or the other get the cold air kit - sticking a bigger mas on a stock intake/tb/filter won't really accomplish anything.
sandman0023 said:I didn't explain everything. I have an 89GT. I have ordered the BBK intake manifold and throttle body for it. Now, which would work better?
In MM&SF Oct 2001 they did a dyno test on a 90 coupe before and after a c/l 76mm mass air AND inlet tube. The system made 9 peak hp @4800rmp and 10 peak ft/lbs @3000rmp. This type of gain is just bordering on what the butt dyno can pick up - and more importantly is it worth the $220+ for a first mod?
Swarzkopf said:What kind of power gain do you expect from a $200 bolt on?
