You can adjust them yourself, but you need a wideband 02 gauge/datalogger to do so. Dyno shops have them, or you can install one in your car as I did. They are relatively expensive compared to most other types of gauges.
You cannot adjust parameters on the Predator tuner itself to the degree that a custom tuner can with Diablo CMR software. For instance, say I had a lean spike in A/F ratio between 3500 and 4000 rpm. The Predator as it's delivered will only allow adjustments in two ranges, 2000-4000 and 4000-7000 rpm. If I richened up the ratio in the entire 2000-4000 range, I would now probably run rich between 2000 and 3500 rpm. A custom tuner with the CMR software on the other hand can adjust for much smaller rpm ranges, and target only the range that needs adjusting.
