Cold spark plug, cold engine?
  • Thread starter Thread starter Cdaniel
  • Start date Start date Sep 11, 2004
Cdaniel
220
Arizona
Sep 11, 2004
  • Sep 11, 2004
I was reading on another list about one guy's claim that a colder heat range spark plug actually dropped the operating temp of his engine.
Never heard that one before. Can anyone else back up his testimony?
2bav8
2,511
Mesa, AZ
Sep 11, 2004
  • Sep 11, 2004
Pure coincidence for your buddy.
The weather was probably 20 degrees cooler that day, lol
A colder plug mearly reduces the temp at the spark plug electrode.
It in no way will reduce the operating temperature of the motor.
ratio411
3,870
73
109
Pensacola FL
Sep 11, 2004
  • Sep 11, 2004
I don't know how it works, or if my experience was weird, but...
I used hotter plugs once and my engine detonated, ran hotter, then overheated. All in the first day.
The second day the car got the cooler plugs.
Dave
Cdaniel
220
Arizona
Sep 12, 2004
  • Sep 12, 2004
That's what I think, but this guy claims same conditions,different temp
Who knows?
Cdaniel
220
Arizona
Sep 12, 2004
  • Sep 12, 2004
Dave
So how much of a heat range change did you make?
rbohm
6,698
550
204
tucson,az
Sep 12, 2004
  • Sep 12, 2004
Dave
a hotter plug, since it runs hotter, can cause detonation. the overheating may be because you had to run the engine harder to overcome the power loss of the detonation, or your cooling system is marginal to begin with and the combination of problems caused the overheating. likely though it was a coincidence. abd 2bav8 is right, a colder plug does not reduce operating temps, just plug temps.
O
Ozsum2
695
  • Sep 12, 2004
Doesn't gas combust at the same temp? Physics folks.
Cdaniel
220
Arizona
Sep 12, 2004
  • Sep 12, 2004
Physics, Shmisics. I'm no Physicist or a Physician even, and I didn't sleep at a Holiday Inn last night. Just a common sense gear head. And my common sense agrees with your Physics, so I'll take your word for it.
Don't grade me on spelling either
ratio411
3,870
73
109
Pensacola FL
Sep 12, 2004
  • Sep 12, 2004
I went up one heat range on my plugs. You are supposed to use the hottest plug you can, without detonation, for the best power.
This was the first and last time this engine had ever overheated.
I will say that I don't think it would change your engine temps. If you were to introduce physics, it would likely be opposite.
A cooler plug gets to be cooler by releasing combustion heat into the cooling system quicker, therefore it would raise coolant temps.
A hotter plug keeps heat from transfering as fast into the coolant, so your water temps would be lower if it had any effect at all.
Dave
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
J
can you use the heads off a H O 302 to put on a regular 302 engine
  • Jan H
  • Feb 25, 2026
  • Other Auto Tech
Other Auto Tech May 17, 2026
nickyb
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
R
New Member, needs help with built '04 engine
  • rollo19
  • Aug 6, 2025
  • The Welcome Wagon
The Welcome Wagon Aug 6, 2025
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
