  • 2005 - 2009 Specific Tech
Cold start ups
  • Thread starter Thread starter Fast05
  • Start date Start date Jan 27, 2006
1 of 2 Next Last
Fast05
409
Corpus Christi, TX
Jan 27, 2006
  • Jan 27, 2006
Ok, I have had a problem with my stang for a while now. If I start the car up cold and start driving right away, the engine starts to act like its going to putter and die and starts to make the car buck. Almost as if the throttle was opening and closing though I'm not moving the gas pedal up and down...
So I push the clutch in and let the car coast, go into second and it does it again. I roll the car to a stop, put it in first and go again but this time no problems, although this even always seems to trigger the check engline light. When I run diagnostics I always get a code that reads O2 Sensor Bank 1, Sensor 2 stuck lean. Today though, when this happened, I ran the diagnostics again and I got 3 codes:
O2 Sensor Bank 1, Sensor 1 stuck lean
O2 Sensor Bank 1, Sensor 2 stuck rich
Systems readiness test not complete
I don't remember the exact code for that 3rd one....but it's close
I probably need to get the car custom tuned on a dyno, but have had no luck finding one in my area, if anyone knows where to search for one ? I live in Corpus Christi, TX and am willing to drive if necessary. I still think that with my canned tune the car is running lean so maybe this is the cause? Any ideas?
Thanks in advance for any help or advice
P
PanhandleGT
  • Jan 27, 2006
I have the exact same problem. I also have the JBA's but with steeda CAI and 93 tune, although my check engine light never comes on. I have noticed a substanial loss in performance the last couple of weeks and decided to pull her to a shop in nearby atlanta (8 hours). Im fed up...no one here has a clue. My best guess is that when I installed the L/T's there were four O2 holes with only 2 O2 sensors. Since they reached the holes toward the tail end of the exhaust I put them in and pluged the fronts. I have been told to buy extensions and do the opposite. Good luck.
K
klee024
  • Jan 27, 2006
I have been having the same issue, but my car is completely stock. It bucks when you try to start driving if you don't wait a few seconds. If I wait for 15-20 seconds it is completely fine, but I am not exactly thrilled about it.
TAP4636
99
Chicago
Jan 28, 2006
  • Jan 28, 2006
You probably shouldn't drive it completely cold anyway. During the winter months, you should let it sit idle for a bit before driving.
K
klee024
  • Jan 28, 2006
Yeah...That was my thought, and why I wasn't tremendously worried about it.
Fast05
409
Corpus Christi, TX
Jan 28, 2006
  • Jan 28, 2006
Yea, I forgot to mention that if I let the car idle for aboue 2-3 minutes and warm up she gives me no problems...it just seems weird though that I can't get in the car and go if I'm in a hurry. It's not that big a deal but I've never had a car with a problem like this
L
LarryS
Jan 28, 2006
  • Jan 28, 2006
My engine on my 06 GT idles way too fast for a minute or so. That can be fixed with tuning. I would be willing to bet your problem could be fixed with tuning with a tuner that has full access to the PCM, ECT or what ever our computer is called.
My 98 Camaro's cold idle was terrible stock until I got HP Tuner. I tuned it myself and now it's perfect even with the addition of a big cam.
JTGrant
775
GA
Jul 13, 2006
  • Jul 13, 2006
this is the same problem that I am having
JTGrant
775
GA
Sep 7, 2006
  • Sep 7, 2006
any updates?
Fast05
409
Corpus Christi, TX
Sep 8, 2006
#10
  • Sep 8, 2006
  • #10
Unfortunately still dealing with this problem. I am ready to slap my stock exhaust back on and forget about it
anthony05gt
1,262
Maryland
Sep 9, 2006
#11
  • Sep 9, 2006
  • #11
Take it back to the guy who supplied the tune. Sounds like he needs to richen up the fast idle settings for cold starts. It's an easy fix.
O
official_style
261
#12
  • Sep 9, 2006
  • #12
i got the same problem. the problem is, that your o2 sensors are not getting warm quick enough, and its running poorly till they heat up. i have american racing longtubes. everyone who has LTs is having this problem. i think the solution is to have the tuner set it so that the o2s dont turn on for a longer period of time. im going to mustang magic to find out about this. and yes mine throws a code when this happens, if i drive. if i dont it wont throw the code. get some MIL elims or turn off your rear o2 sensors. as for the guy who only said he installed 2 o2 sensors and plugged 2 holes? what are u talking about these cars have 4 o2s stock!
JTGrant
775
GA
Sep 10, 2006
#13
  • Sep 10, 2006
  • #13
all people with this problem need to keep this thread alive. we need to find a fix.
Fast05
409
Corpus Christi, TX
Sep 10, 2006
#14
  • Sep 10, 2006
  • #14
I am going back to my tuner next Saturday (16th) and going to have them look at the tune again. He keeps telling me that my 02 sensor must be faulty and that's why it keeps triggering my CEL but when I had my bamachips tune I never had this problem. Only problem I had with the bamachips tune was the rough cold start up and ocasional ping which wasn't good.
Anyway, with my current tune I'm still getting rough cold start up but not near as bad as I was before. I had taken it back to the tuner about a month ago and they adjusted the time needed for the 02 sensors to warm up so I'm guessing it just needs to be extended a little bit longer. As far as the CEL light coming on, it only does that if I cruise with the RPMs below 2500 so I know it's not the 02 sensor. If I get the problem fixed I will have him email me the tune.
:SNSign:
JTGrant
775
GA
Sep 10, 2006
#15
  • Sep 10, 2006
  • #15
let us know what happens.
O
official_style
261
#16
  • Sep 12, 2006
  • #16
i went to my tuner today, and they havent found a fix yet. the problem is the o2s are just not getting warm fast enough. your tuner was able to make your car run in the warm up mode for longer, before turning the o2s on? i thought this wasnt possible? as of now im just letting it warm up. and i get the same code, bank 1 sensor 1, i already changed it, so its not the sensor. only happens if its cold. someones gonna figure this out eventually.
Jenns01TA
37
Sep 13, 2006
#17
  • Sep 13, 2006
  • #17
So should I chime in here? I am not sure how much these tuners are compensating for the degree of control the the o2 sensors have in the grand scheme of things. The VVTS + Heated O2 circuit calculation and alogrithm that needs to compensate for the increase in AF, etc. etc. To properly tune for all the variables takes a computer science specialist with a mechanical flare and a strong EEC/PCM understanding.
I am but a young lady who has a deep fixation and love for the Stang. Specifically, the amount of pure data "logic" and mathmatical alogrithms necessary to make these things perform properly and optimally.
I gave up my tools and traded them in for a computer. This stuff is amazing, although, I miss the simplicity of pre-OBD/FI engines.
Instead of boring you guys with the fundamentals, I am going to link this handy little "arm chair mechanics" guide to 02 Sensor diagnostics. Please do not flog me for hyperlinking this.
http://www.aa1car.com/library/o2sensor.htm
When you get to the middle portion of the dry tech talk you will find an answer to your proverbial question "WTF?"....
We love to modify these Stangs. Given. But, these modulated vehicles have more computer modules than the space shuttle and leave more room for error.
I hope this helps. I do not have the answer on how to "code" the correction to the Voltage and Loop calculations required for each of your modifications, but this should at least point you in the right direction.
Good Luck Fellas. This is one reason that I have kept my Daily Driver S197 Stock. This EEC/PCM with OBD-II, VVT and DBW is a little too much for this gal.
iskwezm
4,159
20
79
Rowland Heights,California
Sep 13, 2006
#18
  • Sep 13, 2006
  • #18
wow, talk dirt again
O
official_style
261
#19
  • Sep 13, 2006
  • #19
that was actually pretty interesting! now i know what these stupid things actually do lol. it seems to me from reading this that setting the car to stay in open loop would solve the LT cold start problem. am i right?
Jenns01TA
37
Sep 13, 2006
#20
  • Sep 13, 2006
  • #20
Final Answer? You have just answered your proverbial question of 'WTF" ? You now have your marching orders, Captain.
Caution should be exercised when considering locking an open loop signal with the PCM/EEC-V/OBD-II. Since no signal is received from the O2 sensor, as is the case with the cold engine start sensor bank DC throw, the computer will order that fixed/unchanging rich fuel mixture. This in itself will cause additional EEC/PCM issues that will have profound and punishing ramifications on the llife of the engine.
Since there are no WRAF sensors available that I am aware of for Ford, what in fact needs to be done is a change in the control voltage level sent from the PCM to the O2 sensors. There needs to be compensation for the deviation from the stock AF ratio that the PCM is calculating.
I am NOT your gal. You will need to find someone who is capable of calculating the deviation to balance out the AF deviation to voltage minimum/maximum on the heated 02s.
It is interesting huh? Most of us have just scratched the surface of the technical knowledge needed to keep these beasts running at optimal levels, especially after exhaust and intake modifications.
"I LIVE FOR THIS....". -Vin Diseal -
1 of 2 Next Last
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
2005 - 2009 Specific Tech Sep 6, 2025
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
