Combining MM K-Member with QA1 coilover
Thank You for your response ..
-The parts are new.
-The coilovers are for 79-93 mustangs. I got them from summit racing. Part# HAL-H2001.
-The K-member and control arms are Maximum Motorsports. I bought them from 50resto.
-K-member part# MM-MMKM1.
-Control Arms part # MM-MMFCA5 .. front offset.
-The base of the strut is hitting the control arm. I tried to relocate the control arm to the lower mounting position, but the strut will also hit the control arm and the geometry will be messed up as the control arms would not be vertical.
I used to run AJE k-member and control arms, with strange engineering struts and Granatelli coilovers without problems, but the handling was not so good for agressive street driving.
