combo question's
91lxntch
247
altoona,p.a
im thinking about ordering the summit trick flow top end kit....
what lifters should i run (stock/aftermarket) to make it work it doasent come with them...
what oil pump should i run or should i stay stock....
and should i upgrade to the track heat springs/guides..someone said they arent very good on the twisted wedge heads any truth......
im trying to debate wether to get that kit or a s trim kit
either way ill have ...
70mm t.b
76mm c&l mass
255 high pressure pump
30 #inj(n/a) or 36#inj(sc)
afpr
what would you do ....8-10 psi s trim with a power pipe and msd...or the h/c/i
I really dont think you can go wrong either way. With the Trick Flow kit you wont have to run premium gas, though. I personally think that doing the engine before any power adders will be the most satisfying.
Use the stock lifters unless you want to spend $350+ on aftermarkets and unless you have an engine with loose race tolerances, use a standard volume oil pump as well. Remeber to use an FMS or ARP pump shaft too.
ok so my factory lifters i got now will work fine...prob why they dont come with the kit.....if i do go h/c/i ill also be adding a 125-150 wet kit(nitrous)..
i was told to get a high volume oil pump....do i even need to do one i meen is the stocker thats in there good enough ..do it right the first time .....
