- Dec 13, 2009
- 40
- 0
- 0
i am about to buy this cam kit for my 68 mustang and i was just wondering if anyone has any comments about this cam? its going in a street strip car but i just want some feedback before i make the purchase. thanks
i am putting chevy 1.94s and 1.50s in a set of 65 heads for my 289. it should have around ten and a half to one compression with the flat top pistons i have and i have 430 rearend gears and a t10 4 speed.
all the work done on the heads is free!!! i have machine shop at my community college. even the valves, which i got used from a chevy kid at school. i already threaded and purchased screw in studs i just need the correct thread sealer. also deshrouding should only add about 2 cc max to dome. also rbohm suggested the use of the windsor jr heads on my application and im not sure that my build would be much different.... the only difference is that my hand porting wont be nearly as fine as the windsor jr heads and i have the 1.5 valves not 1.6. but with that said you gentlemen still think its to much for that small of displacement. sorry guys im VERY new to this site. i was just wondering how the power was. it was my fault for not putting specifics in my questions and answers... have you guys ran this cam before and if so how is the power out put of this unit... i am sorry if i have waisted your time.
If you want to enjoy the car at all, I think you'll enjoy the Comp 270 the most. Anything much more than that, and you will really need to start looking at rear end gears, stall speed, etc......
Also, you will still need to verify your valve train geometry, installed spring height, push rod length, blah blah blah.
My 331 is still making about 395 HP at 7000 with a 282S Comp cam. It peaks at 6500 with around 425 HP. This is with fully ported '70 351w heads mind you
I am honestly perplexed why more people who are looking for a lot of HP and are building a Ford SB (289/302 based engine) don't use solid lifter cams. The way to make a small block make power is to make it up top. They generally don't make the torque to make huge HP below 5500 to 6000 rpm.
All I can recommend is that you make that 289 rev!
You just answered your own question here.
If you wanted to build a motor that made all it's power "up top" why did you build a 331 ? And with 351W heads ? And a HP peak at 6500 ? A motor that makes all it's power "up top" (that's in the 3500-7500 rpm range in my book) is fun for about 30 minutes. A motor like your 331 (and mine as well) that "turns on" at 1500 and pulls to 6500-7000 is a lot more fun on the street. With the powerband you have, you could have just as easily had with a hyd. roller. Which is what I've got in my 331 (Ford Z303 w/1.7 rockers) It doesn't float the lifters till somewhere north of 7000, well after it's reached it's peak power.A solid flat will make more power than a hydraulic roller any day of the week. I would be very surprised if the Z cammed motor with canfield heads could put down more than 350rwhp.
I didn't build it to make peak HP. I built it to drive. Maybe someday I'll get a chance to dyno it and see the numbers. Until that point, I'm completely satisfied with it's output and street manners.
