Ok guys I'm scratching my head on this one.....I would like to know which one will work for me. I'm only looking for advice as to which one will work in a roller 331. I won't be buying a custom as this is not an option. One says 69-95 351 and the other says 63-95 289-302????? I want something with a little lope but nothing too radical. The remainder of the parts I have now are in my sig. Help???
Part Number 35-518-8
Engine 1969-1995 Ford
351ci,
Windsor,
8cyl.
Grind Number FW XE274HR-12
Description
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.555 0.565
Duration At 0.006 Tappet Lift 274 282
Valve Timing At 0.006
Open Close
Intake 29 65
Exhaust 77 25
These Specs Are For The Cam Installed At 108 Intake CL
Intake Exhaust
Duration At 0.05 224 232
Lobe Lift 0.348 0.354
Lobe Separation 112
AND:
_________________________________________________________________
Part Number 31-246-3 Engine 1963-1995 Ford
289ci-302ci
8cyl.
Grind Number FS XE274H-10
Description
Intake Exhaust
Gross Valve Lift 0.52 0.523
Duration At 0.006 Tappet Lift 274 286
Open Close
Intake 31 63
Exhaust 77 29
These Specs Are For The Cam Installed At 106 Intake CL
Intake Exhaust
Duration At 0.05 230 236
Lobe Lift 0.325 0.327
Lobe Separation 110
351ci,
Windsor,
8cyl.
Description
Intake Exhaust
Open Close
Intake 29 65
Exhaust 77 25
Intake Exhaust
Lobe Separation 112
AND:
289ci-302ci
8cyl.
Description
Intake Exhaust
Open Close
Intake 31 63
Exhaust 77 29
Intake Exhaust
Lobe Separation 110
