Cam is in perfect condition. Put it in and realized it was to small for my combo. Only has about 500 miles on it. Specs below. Asking $160 shipped
Brand COMP Cams
Manufacturer's Part Number 35-518-8
Part Type Camshafts
Product Line COMP Cams Xtreme Energy Camshafts
Summit Racing Part Number CCA-35-518-8
UPC 036584031574
Cam Style Hydraulic roller tappet
Basic Operating RPM Range 2,200-6,200
Intake Duration at 050 inch Lift 224
Exhaust Duration at 050 inch Lift 232
Duration at 050 inch Lift 224 int./232 exh.
Advertised Intake Duration 274
Advertised Exhaust Duration 282
Advertised Duration 274 int./282 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.555 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.565 in.
Valve Lift with Factory Rocker Arm Ratio 0.555 int./0.565 exh.
Lobe Separation (degrees) 112
Computer-Controlled Compatible Yes
Grind Number FW XE274HR-12
Brand COMP Cams
Part Type Camshafts
UPC 036584031574
