You will lose some bottom end. I ran the comp box upper with stock heads and a Cobra lower for a few months before going 351w. The loss of low end was almost intolerable. Power was pathetic under 3500-4000rpm. I would recommend the Cobra lower with this intake as opposed to the stock intake configuration.
The comp cam box intake will allow more engine noise to be audible as there is less mass in the intake to muffle noise. I would not recommend this intake for boost however. It is difficult to get the intake to seal properly, especially where the top and bottom of the box intake bolt together and also where the vac fittings thread into the intake. Also, care must be taken when bolting the intake together, as the polymer material could crack if over-torqued.
In all I think very highly of this intake. I think it is a great value, just be aware of the tradeoffs.
:Word:
jason
