Comp Cams XE270HR
  • Thread starter Thread starter LXSTASY
  • Start date Start date May 6, 2005
LXSTASY
932
Long Island, NY
May 6, 2005
  • May 6, 2005
I have AFR 165 heads and a ported cobra intake. I plan on 24# injectors. I was looking into the comp cams XE270HR. It has a 114 l/s so it should idle.
Specs:
270/276 advertised
218/224 @.050
"512 lift both intake and exhaust with 1.6RR
I was wondering if my stock AFR valve springs would be good. Some people say it isn't but AFR says on the website that they are good to .550" lift.
Anyone with this cam?
Thanks
Dan
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
May 6, 2005
  • May 6, 2005
Not sure on the spring situation, but you may find the XE270hr-12 a better fit to your combination..I run it with scorpion 1.6's and the computer takes it all in very well..the idle/power curve is excellent for an OTS cam.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
May 6, 2005
  • May 6, 2005
The AFR's are almost intake biased in their flow characteristics; a similar XE cam that's less exhaust biased may well work even better.
Grn92LX
Fidanza Man!
6,819
64
129
New York
May 6, 2005
  • May 6, 2005
With a comp XE cam, you ARE changing valve springs end of discussion. Unless its worth potentially toasting a shortblock to save $120? With that said, why cheap out $50 on a shelf cam when you can make more power with a more aggressive custom? You ARE changing springs like I said. If you don't wanna change springs, put a tfs 1 in installed on a 108* centerline.
LXSTASY
932
Long Island, NY
May 7, 2005
  • May 7, 2005
My concern is if a 112 L/S cam will idle right in my car?
Also I was looking at the NX264 cam. Is that a better cam as described Michael Yount?
9
90Notch
1,046
Westwood, MA & yes it's killing me that I'm no
May 7, 2005
  • May 7, 2005
"My concern is if a 112 L/S cam will idle right in my car?
Also I was looking at the NX264 cam. Is that a better cam as described "
Its the overlap that causes the idle issues (which happens to be a product of vlv specs) and neither XE270-12 or XE270-14 have that much that it would be a concern. As for the NX cam it is even further bias towards exhaust so going by MYs comment it's going in the wrong direction.
I would run the XE270 (XE270-12) of the two Comp cams (comparing to the NX one you listed) but I wouldn't run the AFR stock springs. It's not so much the lift you need to worry about butmore the spring pressure to make sure vlv don't float.
SBF Head Flow Table - Work in Progress
  • Noobz347
  • Sep 29, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 30, 2025
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
V
pushrod 5.0 (MILD/ Torque) turbo build for an old scout II help
  • vz58
  • Apr 21, 2024
  • Other Auto Tech
2K
Other Auto Tech Jan 21, 2026
Flyboy60
F
Specific Cam Questions that Google can't seem to answer...
  • ChillPhatCat
  • Jun 20, 2024
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Jun 22, 2024
ChillPhatCat
I
289 cam break in help
  • iaff284
  • Aug 19, 2022
1965 - 1973 Classic Mustangs -General/Talk- Aug 19, 2022
iaff284
I
