that has forged pistons, new rings, bearings, rods........ Stage 2 PI heads from Heads up Performance, 30lb injectors and the xe278 cams
Good luck
The lobe seperation seems fine for daily driving. The lift specified is 550, but is that for both the intake and exhuast ? If both the intake and exhuast have the same lift, it sounds like a blower cam. For a n/a application, you probably want a bit more on the exhuast side than the intake. The duration seems fine as well.streetstang03 said:are custom grind Comp Cams with these specs ok for a n/a daily driver?
Specs:
Duration:
Intake@50: 234
Exhaust@50: 242
Lobe Separation: 114 degree.
Valve Lift: 550.
RPM Range: 1800 to 6000 RPMs.
Specs:
Duration:
Intake@50: 234
Exhaust@50: 242
Valve Lift: 550.
Dark Knight GT said:... I'm going to come up with my own custom cam design for my application, and I think I need to know more about how the cams work on the 4.6.
