Electrical Complete Electrical Power Loss
Got an 02 Mustang V6 5-speed that is completely dead.
The battery has been load tested and is fully charged. The starter and solenoid have been tested. All connections are good with no broken or frayed wires. I've power into and out of every fuse in the box. I've got power into and out of the ignition switch.
And the car is still completely dead. I have no idea what to check next. Any help would be appreciated.
So Steve, completely dead means no crank when you try starting?
Yes, that's what it means. I can jump the solenoid with a screwdriver and it will crank, but with no power anywhere else, there's no spark or fuel.
I have been over ALL the common causes for a problem like this backwards and forwards. I need help with uncommon causes. Maybe a hidden fusible link that the wiring diagram isn't showing me.
Im working on a separate issue on my impala ss (no crank). Turns out the ecm is not getting a signal that the car is in park, as a result it wont turn over! Thats what made me think of the ccrm on your car. Report back on what you find
Before the power loss, it wouldn't start for some reason. The check engine light was on so I checked diagnostic codes and got a P1000. My initial research indicated that it could be a bad ECU. That is when I made that thread.
After digging a little more, I found that the P1000 has different meanings depending on manufacturer. On Mustangs it just means that the ECM was unable to finish its diagnostic check.
I started investigating other possible causes for the no start and that is when the total power failure occurred.
I hooked up a good battery, everything powered up, I turned the key, the starter clicked and the power died. A few minutes later, the power came back on and I tried to start it again with the same results.
The power came back a third time, I tried to start it and the power died completely this time.
And here we are.
