Complete SN95 Brake conversion for Foxbody
Tubbed Pacecar
Woops ! This should be in classifieds ! Moderator, please delete, as I have already re-posted to the appropriate forum.
Guys: I had been hoarding aways all the bits to do the SN95 conversion on my Foxbody Stationwagon.....then some *&^%$# tool in an Acura TSX drilled me, and wrote the car off
So, now my parts stash is for sale. I am initially offering it as a COMPLETE PACKAGE.....if I don't get anyone who wants to step up for the complete package, I may consider smaller packages, but I WILL NOT be selling individual bits (such as banjo fittings, or other lil parts,etc) seperately. There is a list below, and even with the deals that I get, there is about $3500.00 in parts alone (no allowance for labour for diff included). Offers over 3K considered.About the only thing not included that you will need is fittings to adapt the ends of the braided steel brakelines(which are metric) to your fox (imperial) hard lines.
The diff is a Fox 8.8 w/North Cobra Brackets to adapt the SN95 Calipers w/cobra rotors. The diff was disassembled, tanked, blasted, powdercoated NEAR CHROME, then reassembled with all new bearings(carrier, axles,etc), as well as new frictions and steels in the posi. The axle ratio is 3:27....
Any part not indicated as USED is BRAND NEW.
And F.Y.I....I'm in Alberta's CAPITAL CITY
Ford Motorsport Cobra Front Calipers
FRPP Prop valve plug kit
Powerstop Cobra Front Rotors
Powerstop Cobra Rear Rotors
Hawk Rear Brake Pad Set (Cobra)
Russel 5 Pc Braided Brake Hose Kit
Neoprene 8.8" Diff Cove Gasket
Wilwood Adj. Prop. Valve
Wilwood 2lb Residual Pressure Valve
Energy Suspension Urethane Rear Control Arm Bushings
Energy Suspension Urethane Offset Rack Bushings
North Cobra Caliper Brackets C/W Bolts for Fox 8.8" Diff (c/w e-brake cables)
Cobra 10mm x 1.0 Banjo Bolts
Russel Speed Bleeders
Brake Line Adaptor Fitting
Lincoln 1" Bore Master Cyllinder
8.8" R/P Inst'n Kit
8.8" Posi Frictions & Steels
8.8" Wheel Bearings & Seals
Stainless Steel Balljoint Stud Spacers
Ford Front Rotor Dust Shields
Ford SN95 E-Brake Cable Clips
Used SN95 Front Spindles,Calipers, Rotors,Rear Calipers,brackets,etc
Used 8.8" Fox Diff
Used Ranger 5 Bolt Axles
Used BBK 2" Lowering Springs for Fox Mustang
Used 17" '99 GT Wheels C/W 245/45/17 Dunlop Tires
Powdercoating of 8.8" Housing, Brackets,etc
James
