Completely Baffled
  • Thread starter Thread starter AlexGranda
  • Start date Start date Jun 16, 2011
First Prev 2 of 2
A
AlexGranda
9
#21
  • Jun 20, 2011
  • #21
Ok...I did get it running after advancing the dist as far as it would go (the vaccum can was hitting the goose neck) but I try to restart it and it would not restart at that point...I would think the that the dist would be off one or two teeth but I double checked the TDC and number #1 piston and it is dead on...Any suggestions....When it was running it idle a little rough but at the higher RPMs it was running great....
68CoupeWimWhite
Pataskala, Ohio
Jun 20, 2011
#22
  • Jun 20, 2011
  • #22
Alex,
Be safe in Iraq and if you need any parts for your Military ride, hit me up DSN 850-5047. I work for DLA and will make sure you aren't on foot patrol. Thanks for what you do, From a Vet.
robbz28
775
Epps, LA
Jun 20, 2011
#23
  • Jun 20, 2011
  • #23
that is EXACTLY what my car did when it was out 180....all the way to the water neck it would fire up and run...sort of....I tried moving it over a cog or two and it wouldnt fire at all....when i finally turned it over 180 it ran like a champ....quadruple check brother...and stay safe!
A
AlexGranda
9
#24
  • Jun 21, 2011
  • #24
Robbz28...Will do...Tried everything else...Thanks and will let you..Thanks Bro
A
AlexGranda
9
#25
  • Jun 22, 2011
  • #25
All thanks for all the help. I found the problem. My son installed the timing gears while I was away and forgot a couple of things. The key in the key way was not installed and the pin on the camshaft as well. Not sure how the engine if turned over or even started but it explains everything....Go it running last night and just in time for me to get on a plane to head back to Iraq tommorow morning...I will leave the rest to my son to finish but at least we got it running....I told him to use this site if he runs into problems...all of you have been a great help...
robbz28
775
Epps, LA
Jun 22, 2011
#26
  • Jun 22, 2011
  • #26
Glad you found out what it was! Could have been bad if that car would have ran like that, might have ended up with some bent/broken valves! Anyway, at least thats one less worry while you are away, thanks for your service and come back safe!
C
chrisboss429
18
#27
  • Jun 22, 2011
  • #27
Be safe and thanks for keeping my family, myself, and my countrymen safe! Glad your issue is resolved.
First Prev 2 of 2
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
Electrical 88 EEC Injectors batch firing ?
  • Dustin 86GT
  • Dec 8, 2025
Fox 5.0 Mustang Tech Jan 8, 2026
gkomo
Electrical 92 Fox 5.0 no start
  • xwhiskeyechox
  • Apr 24, 2025
Fox 5.0 Mustang Tech Apr 25, 2025
AeroCoupe
Engine 1994 5.0 refuses to idle
  • FordFanatic1894
  • Jul 20, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jul 22, 2025
General karthief
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
