composite or bronze?
  • Thread starter Thread starter thinblueline65
  • Start date Start date Sep 5, 2011
T
thinblueline65
10
Whitsett, NC
Sep 5, 2011
  • Sep 5, 2011
Anyone running a composite gear? I have run bronze gears over the past 10 years. Yes they work, they wear out after awhile. Not a big deal but will a composite last longer? my set up 65 coupe with a 347, afr 205, howards billet solid roller 624 640 lift, msd 8582. High volume oil pump. I turn the car about 7500, will the pump be to much stress on the composite and make it come apart? any suggestions? opinions? thanks for the imput
coolblue65
1,224
Algonquin, IL
Sep 5, 2011
  • Sep 5, 2011
When I built my 347 after much research and talking on the phone with Comp Cams and MSD I ended up going with the Composite gear. I haven't pulled the dist. since the install, but so far so good.
calpolymustang
217
Santa Rosa, CA
Sep 6, 2011
  • Sep 6, 2011
i went with MSD 85833 for my roller cam. not sure if your cam is tougher than the stock 5.0 roller cams, but mine works fine.
the gear is steel, and replaced the iron gear used for flat tappets.
ive had zero problems, and have had it in there for 20k miles. ive pulled it several times, when removing the inake, and shows no signs of issues.
its $68 at summit
blown65
1,938
Queen Creek Arizona
Sep 6, 2011
  • Sep 6, 2011
Few on another board had the composite break at the roll pin area.
Some of the cams can use a steel gear instead like calpolymustang used. My old cam from Crane was suited for it.
T
thinblueline65
10
Whitsett, NC
Sep 7, 2011
  • Sep 7, 2011
ended up getting a composite. should be here by the weekend hope it turns out ok. thanks for the replies
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
C
347 stroker power estimate? Expected 1/4 mile run?
  • clayton seiders
  • Nov 29, 2023
  • The Welcome Wagon
The Welcome Wagon Nov 29, 2023
clayton seiders
C
R
Bad Vibration at 2000-3000RPM
  • Rona
  • Apr 16, 2022
6K
Fox 5.0 Mustang Tech Jul 20, 2023
85GTStangGuy
E
For Sale 1989 LX Notch 410ci 85mm turbo 8 pt cage 9" rear end
  • EightyNineFive
  • Aug 22, 2021
4K
Fox Body Mustangs For Sale (1979-93) Jun 18, 2022
Freakinstang
F
