COMPRESSION QUESTION
  • Thread starter Thread starter rei-04
  • Start date Start date Nov 18, 2004
R
rei-04
63
TX
Nov 18, 2004
  • Nov 18, 2004
I have a 93 gt and was wondering if I can test my compression with my upper manifold off? This will be the first time doing this, so what #'s should I be looking for and what is to low of a compression. Also does anyone know if I will use the long reach adapter or the smaller adapter on my 5.0 I am installing used 24# injectors and was wondering how I could test each one. I know the noid light works on each of the injector harness slot, but how do I check the injectors themselves. I guess I will run two compression test, one with the 19# injectors and another test with the new 24# injectors. Will these two injectors give me two different compression rates? Thanks for the help.
Mike86Stang
Advanced Member
Apr 11, 2000
10,296
Red Lion, PA
Nov 18, 2004
  • Nov 18, 2004
The compression will not change without a change in air flow or combustion space. Injectors control fuel not air therefore it would make no change in the cranking compression.
Yes you can check it with the upper off... just be sure to turn off you FP & disable your coil.
Mike
M
Misfire
  • Mike3
  • May 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 30, 2026
Mike3
M
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
C
Engine Cylinder 5,,7, & 8 run significantly cooler than the other cylinders
  • Crisfixes
  • Sep 27, 2025
Fox 5.0 Mustang Tech Sep 27, 2025
T
  • Locked
Digital Tuning A9l issue or something else
  • Tufgriz
  • Sep 11, 2025
Fox 5.0 Mustang Tech Sep 11, 2025
T
Fuel Looking for a little guidance
  • Tufgriz
  • Sep 11, 2025
Fox 5.0 Mustang Tech Sep 12, 2025
