COMPRESSION RATIO info..
  • Thread starter Thread starter 67staaang
  • Start date Start date Apr 27, 2005
  • 3
First Prev 3 of 3
Route666
1,652
Brisbane, Australia
Apr 29, 2005
#41
  • Apr 29, 2005
  • #41
Oh and why why why haven't I posted one of my favourite articles on compression ratio???
The Power Squeeze:
http://www.popularhotrodding.com/tech/0311_phr_power_squeeze/
D
D.Hearne
11,730
south louisiana
Apr 29, 2005
#42
  • Apr 29, 2005
  • #42
whwright said:
I think you guys are right on the money when you say that 9:1 or so is optimum for a street engine. FWIW: my 460 runs 9.5:1 and I haven't noticed it detonating at all.
Wayne.
Have you pushed the tuning to the limits to get it to detonate? Like advancing the timing as far as possible? Then trying higher octane fuel? IMHO, 9.0 to 1 is about the lowest I'd comtemplate running on the street, with 87 octane gas, 9.5 to 1 should also be possible with 87. 10 to 1 or higher with higher octane fuel. My 68 Merc's 10.25 to 1 390 is fine with 89. My 331 has a 10.4 to 1 ratio and will also run 89 with the timing backed off, but really likes 93 with more timing. When I first fired it up, it had 87 in it. It didn't just ping, it HAMMERED with that stuff. That was the first time I've ever heard detonation that bad that I can recall. And I hope I never have to hear that again.
Route666
1,652
Brisbane, Australia
Apr 29, 2005
#43
  • Apr 29, 2005
  • #43
89 and 10.4 eh? What's your quench distance? (I've probably already asked you before but I've forgotten if I have.)
Would it be better to run 11:1 with a 98RON fuel (93AKI) or 10.5:1 with a 95RON fuel? (89AKI)
The 98 is more scarce, but burns more efficiently and cleans the engine apparently, but the 95 is more readily available and slightly cheaper, although if the motor is built for it, you should get better mileage from the 98 so the price basically doesn't come into it.
D
D.Hearne
11,730
south louisiana
Apr 30, 2005
#44
  • Apr 30, 2005
  • #44
The piston clearance on the 331 is .003" head gasket thickness is .043. The 331 will run with 89, but you have to retard the timing some and it does ping slightly occasionally. It would be better to mix 87 and 93 in a 50/50 mix to get 90 octane, as it would cost the same as what 89 goes for here. That's what I've found to be how the oil companies make a few extra dollars off us, they sell midgrade ( 89) for ten cents more than 87 and ten cents less than 93, in effect you can get 90 octane for the same price by mixing it 50/50 at the pump yourself. -----------------------------------------------------------Now on my 68 Mercs 390, I don't recall what the piston to deck clearance was, but it's got the stock std bore cast flat tops in it and Felpro gaskets that are I believe .042" thick instead of the .020" stock steel shims it came with. That reduced the ratio down 1/4 point from 10.5 to 1. That and the Crane Energizer cam has allowed it to run on 89 octane where it required premium before.
Route666
1,652
Brisbane, Australia
Apr 30, 2005
#45
  • Apr 30, 2005
  • #45
Cool, it'd be interesting to see if you could run on 89 without retarded timing if you closed up the gap to .035 or so. Sure the CR would increase too, but I'd like to know just how handy squishing the mix can be.
D
D.Hearne
11,730
south louisiana
Apr 30, 2005
#46
  • Apr 30, 2005
  • #46
Well, I had actually intentionally used thicker gaskets to reduce the comp ratio when I built it.(the ratio was a tad more than I wanted to take a chance with at around 10.7 to 1, if I recall correctly) I had these heads on a 302 shortblock before and had them milled .060 to increase the comp ratio in it. The Canfields were supposed to be 58 cc chambers, but turned out to be 64ccs. That's the chance you take in buying on ebay. Still got good heads for a good price, just the woman I bought them from made a mistake in the chamber specs. Milling them .060 reduced the chambers to 57 ccs.
Route666
1,652
Brisbane, Australia
Apr 30, 2005
#47
  • Apr 30, 2005
  • #47
Yeh you probably did the best thing to do, I probably would have gone that way rather than get right up near 11:1, even though I'd build a motor with that CR no worries, it'd have to also use some tricks ($$$$) that would help out against detonation.
Soaring1
Banned
Jan 3, 2003
144
Texas
Apr 30, 2005
#48
  • Apr 30, 2005
  • #48
You guys are trying to make rocket science out of a simple equasion.
http://e30m3performance.com/myths/more_myths1/comp_ratio/comp_ratio.htm
H
HuKares
90
Canton, Ohio
Apr 30, 2005
#49
  • Apr 30, 2005
  • #49
Some sources to back up my apparent insanity:
Chevy High Performance, paragraph 2
One of many online compression calculators
Hot Rod, 2nd half of second paragraph and the best, simplest description IMO
At least two of those sources are chevy guys, and we all know chevy guys can't math.
I'm sorry, but I have to agree with the others, 11:1.
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Apr 30, 2005
#50
  • Apr 30, 2005
  • #50
You're right, but also check the second post on this page.
  • 3
First Prev 3 of 3
Drivetrain 5th Gear Ratio
  • PonyGTrider
  • Dec 8, 2025
2K
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
L
Engine Why won't the motor start if I have spark and fuel
  • LeviAnderson
  • Nov 20, 2025
Fox 5.0 Mustang Tech Nov 20, 2025
AeroCoupe
P
Air Fuel ratio bung location.
  • Praetorious
  • Feb 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 11, 2026
L
2000 Mustang PATS - Broken Key and Wire - HELP!
  • Laree Taylor
  • May 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
manicmechanic007
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
