compression ratio question
  • Thread starter Thread starter MustangGlx
  • Start date Start date Aug 7, 2004
MustangGlx
147
Connecticut
Aug 7, 2004
  • Aug 7, 2004
at what point do you need high octane?
mustang70
2,445
San Diego
Aug 7, 2004
  • Aug 7, 2004
Generally 10:1 is considered the highest for a street compression. Some people get away with higher because of cam specs and aluminum heads.
Oh, I'm guessing by high octane you mean more than 92.
MustangGlx
147
Connecticut
Aug 7, 2004
  • Aug 7, 2004
yea, im not sure what compression ratio my car has, but i have to put 93 octane in it, i was just trying to figure out rougly what it might be around
thakns
6Stang7
1,470
Livermore, CA
Aug 7, 2004
  • Aug 7, 2004
Like mustang70 said, usually around 10:1, but this isn't always the case. I have seen cars with 11.5:1 that run 87 and cars with 9:1 that needed 91. If you have a set of heads that have quencher chambers, then you will be able to run a lower octane then a motor whose heads don't have quencher chambers. Timing will also be a factor along with air/fuel will also play a minor roll.
G
Octane on the 5.0 Coyote
  • gray owl
  • May 17, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk May 27, 2026
Bullitt347
Drivetrain 5th Gear Ratio
  • PonyGTrider
  • Dec 8, 2025
2K
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
P
Air Fuel ratio bung location.
  • Praetorious
  • Feb 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 11, 2026
D
Early ford 302 heads
  • Dagasser
  • May 4, 2026
  • The Welcome Wagon
The Welcome Wagon May 4, 2026
