Compression Ratio
  • Thread starter Thread starter AnthonyR23
  • Start date Start date Mar 4, 2008
AnthonyR23
661
Ontario
Mar 4, 2008
  • Mar 4, 2008
Is there a compression ratio I should be targeting with components during a build.. eg. 10 to 1
AnthonyR23
661
Ontario
Mar 4, 2008
  • Mar 4, 2008
Just to quickly add to that... I chose a stroker kit.. that said 10.1 compression with 61 . just seeing if I should choose a head that has 61 cc, and how much does intake choice affect this compression ratio... eg. going with r series intake.
backfocus
254
Little Rock, AR
Mar 4, 2008
  • Mar 4, 2008
Are you still talking about that same combo you posted about earlier? If you are do you plan on spraying it or adding any forced induction?
With N/A you could shoot for 9 and to 10:5 and still be streetable. When you get over that mark streetability is usually out the door, but there are exceptions.
If you are or plan to use a supercharge or turbo down the road stick below 9 down to 8.
The intake is not going to effect you compression ratio. That is determined by cylinder head, bore, stroke and gasket thickness. Anything in the combustion cylinder part of the engine.
I am not a intake expert so I will let others chim in that.
I would suggest going on the web and looking at compression calculators. They were a huge help to me when building my motor as the what effects what.
Thats the simple explanation anyway.
enyawix
507
Mar 4, 2008
  • Mar 4, 2008
You need to look at what the cam recommends. Cams with a good bit of overlap like more compression. If you think you would consider a turbo or supercharger you want to keep your
compression as it is.
347HO
462
Seattle
Mar 4, 2008
  • Mar 4, 2008
I 100% agree
You are talking about "static" compression, and has only a little to do with dynamic crompression... which is what the engine is really seeing. The camshaft has a big roll in this area.
backfocus
254
Little Rock, AR
Mar 4, 2008
  • Mar 4, 2008
You are talking about "static" compression, and has only a little to do with dynamic compression... which is what the engine is really seeing. The camshaft has a big roll in this area.
Yes I was, as his question was vary vague and didn't give any info on the setup he wanted, or what his plans were for it. It honestly sounded as if he didn't know anything about a motor, no offense Anthony, it was just the way it was worded.
I know the cam plays in dynamic compression. Especially since it plays in the opening and closing of the valves in the combustion camber. Ed helped me with this as well when he made the cam, which is going in my motor.
I was just giving a crude explanation of what I thought he was asking.
Fast63
717
  • Mar 4, 2008
Yes, when he said "compression ratio" that IS static compression.
347HO
462
Seattle
Mar 4, 2008
  • Mar 4, 2008
Ah... I see your point.
AnthonyR23
661
Ontario
Mar 5, 2008
  • Mar 5, 2008
Regarding vague question... and not knowing anything about a motor. So I pulled my motor dissassembled it which wasn't a problem in the least.. and was fairly easy to be honest. I have it mounted on a stand.. and am going to take the block to the shop and have the neccessary machining done.. Obviously I will have to learn as I go somewhat.. and am going to do what I can myself.. In the past stangnet has been good to help with problems I've run into. Anyways.. so I got alot of advice on which stroker kit to pick.. rod length etc. My next step for myself was to try to learn what I could about choosing components for the top end.. Started off looking at one of the complete kits from tfs that apparently is properly matched.. But had many people give me advice to go with the r series intake instead of the track heat because I guess the 347 needs more air.. Assuming that it probably needs more fuel so that's why I desided on the 35lbs injectors. Because of the different intake and what I have read the cam that would have came with the complete kit wouldn't match the intake well.. that's why I was pointed in the direction of ed for the custom cam.. I really believe I have the ability to learn and do most of this build myself with the help of my dad.. but just thought I would get some helpful advice from you guys on stangnet. Obviously I want to choose good heads that kinda match the intake and that would work well on the 347.. and then have the cam made for the application.. but at the same time I want to consider emissions.. but knowone has givin me any advice on whether the intake will be too much for emissions.. and whether a track heat head would be too much.. I know the custom cam can help.. but before ordering the cam I want to choose a good head and intake combo.. that is powerful, and good for emissions and good for a 347. So me asking about compression is just to try to help.. when looking at the components.. eg. if heads are so many cc's it says it will give you so much compression with a 347 and I would assume compression affects emissions and longevity... anyways just trying to learn here. I am pretty mechanical, but when it comes to engine math.. I definetely have some learning to do.. but that's fine for me!
AnthonyR23
661
Ontario
Mar 5, 2008
#10
  • Mar 5, 2008
  • #10
The most helpful thing would be if someone else has a 347 and is running a trick flow R series intake... and deal with emissions. I would love to know which heads and cam you are running, and if it is a custom cam, which heads would match the r series intake.. and if the r series intake and head choice is too much for emissions.. which combo would be good for emissions .. that is head intake combo.. I can have the cam made based on a good intake head combo while keeping emissions standards in mind. Do any of the trick flow heads or intakes still have egr or emissions controls build in... tfs 350 street kit?
AnthonyR23
661
Ontario
Mar 5, 2008
#11
  • Mar 5, 2008
  • #11
Oh and the initial question.. was more so based on if you were to pick a stroker kit, and it said 58cc would give .. compression 61cc would give .. compression and 64cc would give .. compression.. would you ignore that or would you pick a cylinder head based on what it says like 9. or 8. or 10. lets say there was a target like 9.5 to 1 then would you pick the 58cc 61cc or 64cc heads.. or is this a stupid way to pick the heads.. lets say you picked the heads this way, then picked a good intake for the heads, and then have a cam made based on the other two choices.. In what order do you guys pick the components.. cam first or something?? cause I would think heads first based on if its stroked or not, then intake to match the heads, then cam... that's just my opinion.
347HO
462
Seattle
Mar 5, 2008
#12
  • Mar 5, 2008
  • #12
I know where AnthonyR23 is going with this question.
So, since you know also... please explain to him what static compression will do for him on choosing parts and prior to assembling the engine?
Then, explain static compression while the engine is running and how it does or does not affect emissions? Depending on your answer, then explain why.
Follow that up with your explanation of what static compression he needs to start out with for his "emissions" engine.
backfocus
254
Little Rock, AR
Mar 5, 2008
#13
  • Mar 5, 2008
  • #13
Anthony I it is great that you are trying to learn about this, and I didn't mean you didn't know anything. The original question was just too. vague. I myself am not going to claim to know everything either, but I just relearned most of this stuff myself in building my motor, so it is still a little fresh in my head. Although we will see if it pays off when the motor is started up.
I and many people would ask though that you please you paragraphs in your posts. When it is altogether it is difficult to read.
Now on to the question. I know that many of the Trickflow heads do have emission provisions on them, which ones I am not sure at the moment. But I had this article saved that might help with the explanation of compression. Also you might look an find virtual engine dyno 2000, or something like that. It has compression calculators in it that are interesting to use to see what effects what.
Also have you talked with ED. He will probably steer you toward an AFR head, but will still work with you no matter what. As long as you contact him an assure you are buying from him, he is one of the best resources for you as far as setup and emissions.
Here is the article, it is for chevy, but the idea is what counts.
From Hot Rod Mag:
Dynamic Compression
How to calculate dynamic compression on a small-block chevy
Dynamic Compression
-June 2007-
Question: I am building a 355 Chevy for the street using aluminum flat-top pistons with valve reliefs that at TDC sit 0.024 inch below the deck. The heads are 64cc iron Vortec 062s with screw-in studs and Crane PN 10309-1 springs and retainers for added lift. The cam is a Crane 282-H06. I am able to calculate the head gasket thickness necessary to achieve a static 10:1 compression ratio, assuming the valves are closed for the entire compression stroke. However, with this cam, the intake valve is open until 34 degrees ABDC. Should this be taken into consideration? If so, how do I calculate the actual working compression ratio in an effort to achieve a 10:1 ratio?
Peter Illemann
Goderich, Ontario, Canada
Answer: The compression ratio listed for any engine combo is always the static compression ratio, which is fixed via component selection and machining practice when the engine is built. As you've surmised, it assumes the cylinder is full of air and fuel at bottom dead center (BDC) and that all the mixture is compressed into the top dead center (TDC) combustion cavity. But an engine really doesn't begin making serious compression until the intake valve closes and seals the air/fuel mix in the cylinder. That's why engines with identical static compression ratios can have significantly different cranking pressures, as seen with a common compression gauge. Although part of this is due to displacement differences (a larger-cubic-inch engine is a bigger pump), the main influence is camshaft design. By changing certain cam parameters, it's possible to bleed off cylinder pressure on the bottom end, decreasing fuel octane sensitivity, even though its static compression ratio remains unchanged. The actual cylinder pressure an engine sees is often referred to as dynamic compression, because (unlike the static built-in compression ratio) it changes dynamically according to camshaft variations. The most important of these variations is the intake closing point, because it extends beyond BDC into the compression stroke. Closing the intake later aids top-end power at the expense of low-end torque. Down low, where the engine is most likely to detonate, the late intake closure bleeds off cylinder pressure, effectively dropping the dynamic compression ratio.
Rod length and crankshaft stroke also play into the dynamic compression equation because they alter the piston's position within the cylinder at the intake-valve closure point. How all this comes together is explained by KB Pistons' John Erb: "Consider a 10:1 Chevy with a 3.48-inch stroke, 6-inch center-to-center rods, and a very hot race cam that closes the intake at 90 degrees after bottom dead center (ABDC). This engine will think it is running with 6.17:1 compression and will be happy with 80-octane fuel. As a general rule, the best available pump gas will work with an 8.0:1 dynamic compression ratio. To get 8.0:1 with the preceding rod, stroke, and cam intake closing event, you would need about a 13.2:1 static ratio."
Erb's 8.0:1 dynamic guideline is for classic, old-school, all-iron engines. An advanced, high-tech engine can go a point or so higher-but even with the latest high-tech electronically managed engines, actually shooting for a 10:1 dynamic ratio is way too high. Calculating the relationship between piston position in the bore and intake closing point and then determining the effective dynamic compression ratio requires some pretty serious math, but KB Pistons has a Web-based calculator that makes it simple-just plug in the requested numbers.
Hope that helps a little! I have never had to pass emissions, so I am not sure, but I would stay on the conservative side if I were worried about that, Under 10:1 for sure. I have more to add, but I want to see what other have to say as well.
Fast63
717
#14
  • Mar 5, 2008
  • #14
Are you just trying to be some kind of prick or something? Either way, I'll bite.
I really can't give you any advice on emissions for you because you live in Ontario and I have no idea how they conduct emissions tests over there. I can tell you that if you lived in California like I do, you would fail emissions immediately with a manifold other than stock at most testing places and would have to search around for someone to do it. As far as what comes out your tail pipe, I don't think you will increase your emissions much or at all by having a better flowing intake. If the intake eliminates the EGR valve function, your NOX results will go up quite a bit, and that's not good for passing. Better heads also increase NOX, but again you should use heads that are 50 state legal in order to make sure all your smog equipment is doing its job, like the twisted wedge heads. In order to guarentee a passing of the smog test, you really should use the stock cam, maybe throw on some 1.7 roller rockers, or when you get a custom cam ground, specifically tell the grinder that you need to pass smog and you don't want to inch by. Tell him your whole combo and what your requirements are for passing.
When choosing parts, you should always look at all the parts that will effect your compression before you buy anything. First thing to do is select what compression ratio you want. If you want 10:1 compression, use any combination of parts you want to get you there. The easiest way is to select a 347 kit that says you will get 10:1 compression with a 58cc head and then buy a 58cc head.
Static compression is your compression ratio. It is not how much PSI is in the cylinder when you're cranking it over and measuring it, or when it's idling. As soon as you want to know the PSI in there, you are talking about dynamic compression which is measured when the parts are moving. The cam has an effect on this, as well as your static compression (the ratio), and I think better flowing heads and intake can effect it by allowing more air into the cylinders to be compressed. So, I am not sure what "Then, explain what static compression while the engine is running" means because static compression is only measured by the ratio. That is why it is called static, because the engine is not moving.
The static compression will have an effect on emissions, but not a lot, unless you are going with a crazy amount of compression. I have read material saying that a higher compression ratio will effect your CO, NOX, and hydrocarbon count, but others say it will only affect your NOX count, and from my experience it only affects the NOX, and if it does affect CO and hydrocarbons, it is very little. I run 10.13:1 in my 85 stang and I measured very little hydrocarbons and CO, but my NOX was decently high. Definitely well below the maximum allowed on all accounts. So I would say not to worry about the compression ratio in regards to emissions, just don't go nuts, stay 10:1 or under, because you need to run pump gas anyway, and make sure your other parts are emissions compliant. There are many engines today from the factory with around 10:1 compression so if it was a huge problem, they wouldn't use that much static compression.
Give us a little more detail about the emissions standards in your area. Do they do a visual inspection? If so, how detailed is it? Do you know what the limits are of the emissions that you can put out?
AnthonyR23
661
Ontario
Mar 5, 2008
#15
  • Mar 5, 2008
  • #15
Thanks Backfocus and Fast63... very much appreciated... good article too... luckily they haven't done a visual inspection when I have had the tests done in the past.. just the tailpipe test... I'm at work right now but I can check on on old emissions test what the limits are when I get home... So I don't think I will have a problem with actual parts visually.. like manifold etc. but moreso just on the function of the parts.. Just kinda curious if anyone out there with a 347 has to deal with emissions... wondering what heads, intakes, and cams they are running..
Drivetrain 5th Gear Ratio
  • PonyGTrider
  • Dec 8, 2025
2K
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
393W Stroker with Boost - Need Spark Plug Recommendations
  • 387lx
  • Apr 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 30, 2026
HotFox
L
Engine Why won't the motor start if I have spark and fuel
  • LeviAnderson
  • Nov 20, 2025
Fox 5.0 Mustang Tech Nov 20, 2025
AeroCoupe
