  • 1994 - 1995 Specific Tech
Compression Test Q's
  • Thread starter Thread starter chirs
  • Start date Start date Jul 30, 2005
C
chirs
60
Georgia
Jul 30, 2005
  • Jul 30, 2005
I recently rebuilt my 302, bored 30 over, and used a factory summit piston and ring package. I ran a compression test on one cylinder, and it came up 130. This was slightly alarming but.........I have a few questions. I am at sea level and i believe that the standard pressure is 14.7. The stock replacement kit said the pistons would have 9:1 compression, but i am running gt-40 heads which, if im not mistaken, have a larger combustion chamber and thus would lower compression. The rings have not yet seated, less than 50 miles. I figure my compression ratio is around 8.5-8.8:1. So , i would take 14.7 X 8.8 = 129.36. Correct me if im wrong, but does this look right? Also, will my compression go up further when the rings are seated? I will test all the others tomorrow, was dark here, but should i be alarmed or as long as they are all the same then i should be ok right? Thanks,
Chris
abusedstang
103
East Hampton, CT
Jul 30, 2005
  • Jul 30, 2005
my 94 gt has 143k on the ticker and all 8 cylinders showed 125 psi plus or minus 3 psi. Wasn't sure if the pressure was good. I was just relieved that all 8 were even!!!
HISSIN50
34
129
Jul 30, 2005
  • Jul 30, 2005
That test tells not too much since there are too many variables and not enough data. Comp testing is only decent for relative (cylinder to cylinder) comparison IMHO. There are too many methods and variances in testing to compare absolute numbers. And extreme cams can lower compression.
If the motor is not broken in, that is another variable. I would not sweat it myself. The compression can go up a bit once rings seat.
Good luck Chris.
C
chirs
60
Georgia
Jul 30, 2005
  • Jul 30, 2005
Thanks, upon further reseach, i messed up a few things. One the throttle body is supposed to be held open during the test and the engine is supposed to be a normal operating temp. Neither of which were done. According to the same website, without performing both of those steps, one would experience significantly lower numbers.
HISSIN50
34
129
Jul 30, 2005
  • Jul 30, 2005
Yep. Those are a couple of the variances I was talking about. Having the motor warm does help a good bit (not as much as with forged pistons, but still makes a difference). Also numbers can go up a hair from having all plugs pulled (starter can turn the motor over more efficiently for a given amount of cranking interval).
Relative numbers will be much more important.
Good luck.
C
chirs
60
Georgia
Jul 30, 2005
  • Jul 30, 2005
Thanks again, im not too worried now.
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
D
Engine Questions on compression test results
  • dqureshi06
  • Jan 6, 2025
Fox 5.0 Mustang Tech Jan 7, 2025
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
D
Roller rockers with no compression
  • DPORTER0729
  • Jan 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 23, 2025
mobilly
M
