compression test, quick question
the absolute numbers (if within reason) are not so important as the fact that they should be close in proximity (within 10%). there are enough differences in how people do the tests, it can mess results up.
you can do a wet test after the dry test to check the rings. the larger the delta, the more blowby you got.
good luck.
