only checked 5,6,7, and 8 cuz thats all I needed to, but anyway I got 150 everywhere except #8 which is where I thought the noise was coming from.
#8 read 120-125, checked them all a few times to make sure.
now the book says to squirt some oil down that plug hole and re-test. still no difference.
so book says that confirms the problem is NOT the piston rings at least which basically points the finger at the valve train, warped, bent or cracked valve and/or worn cam/head
gotta get it apart now but worst case you can score a brand new complete head off ebay for about $400 so I guess I'll find out which way will be cheaper.
thanks for the help guys!! :SNSign: rocks
and for anyone that hasn't done a compression test and needs to, its quite easy and can do a good job of leading you in the right direction
btw, this is stemming from this thread...
http://forums.stangnet.com/showthread.php?t=695107
