Compression Test Results
  • Thread starter Thread starter NewToFord
  • Start date Start date Mar 14, 2009
N
NewToFord
318
CT
Mar 14, 2009
  • Mar 14, 2009
I checked the compression on my donor car today to help me in deciding about using the motor or not. All of them checked in about 125. The lowest was 120. Does this sound normal? The car has 55k on it. Do different testers vary? As long as they are all in the same ballpark am I good to go?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 14, 2009
  • Mar 14, 2009
If you did the test on a cold engine the numbers are very good. The fact that you only had 5 PSI difference between high and low is also very good. The engine has to be up to operating temp to get best results for a compression test.
if the engine was still warm, the numbers are a little low, but I would run the engine until it started using more that 2 quarts of oil every 1500 miles.
N
NewToFord
318
CT
Mar 14, 2009
  • Mar 14, 2009
it was basically on a cold engine. I started the motor for about a minute, then shut it off and did the test.
Duncan McDougal
99
Gainesville, FL
Mar 15, 2009
  • Mar 15, 2009
Did you do the compression test with all spark plugs out and at wot? My rebuilt engine has about the same mileage (60k) on it and when I tested it warm I got 150's across all cylinders. A stock compression 5.0 if tested at operating temp has a compression of 180psi new and 140psi at the service limit.
N
NewToFord
318
CT
Mar 15, 2009
  • Mar 15, 2009
No I took one spark plug out at a time, and cranked the motor over and over. I did not touch the pedals or anything else. The engine was cold.
D
Engine Questions on compression test results
  • dqureshi06
  • Jan 6, 2025
Fox 5.0 Mustang Tech Jan 7, 2025
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
Engine 1994 5.0 refuses to idle
  • FordFanatic1894
  • Jul 20, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jul 22, 2025
General karthief
P
Engine Mysterious coolant leak at back of engine
  • palerider94
  • Jan 18, 2026
Fox 5.0 Mustang Tech Jan 19, 2026
AeroCoupe
R
Microsquirt tune for stroked 351W in a foxbody
  • roldy
  • Jul 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Oct 25, 2026
roldy
R
