  • SN95 V6 Mustang Tech
Compression
  • Thread starter Thread starter sau4u
  • Start date Start date Jul 19, 2008
sau4u
  • Jul 19, 2008
1994 mustang v6. I performed a compression test today. 5 out of 6 read 125lbs. #1 read 105lbs. Doesnt burn any oil or blow smoke. How much should a guy be worried about the difference. Thanks.
Skymarshal
572
Dallas
Jul 19, 2008
  • Jul 19, 2008
Squirt a little light oil into the #1 cylinder and repeat the test. If the compression comes up, you're getting ring blow-by. If there is no change, your valves are the cause for the low compression. Once you know the source you can go from there.
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
SN95 V6 Mustang Tech May 23, 2026
DPP
D
2001 v6 New compressor issue
  • badmech
  • Apr 30, 2026
SN95 V6 Mustang Tech Apr 30, 2026
badmech
N
Metal Chunk in Oil
  • nlord
  • Nov 15, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Nov 15, 2025
nlord
N
Engine 1994 5.0 refuses to idle
  • FordFanatic1894
  • Jul 20, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jul 22, 2025
General karthief
D
Roller rockers with no compression
  • DPORTER0729
  • Jan 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 23, 2025
mobilly
M
