Compressor/rad hose
  • Thread starter Thread starter Z06killinSBF
  • Start date Start date Jul 13, 2007
Z06killinSBF
457
McKinney, TX
Jul 13, 2007
  • Jul 13, 2007
I have a GM style radiator in my Mustang. It fit fine until I put my compressor on. Now the radiator hose is ALL over the compressor and with no where to go. Anyone have anysuggestions on how to takle this? Also not much room to go in front as it will hit the fan. Any help, thanks.
Tim65GT
1,149
West Texas
Jul 13, 2007
  • Jul 13, 2007
I just switched to a crossflow radiator and knowing that the rad hose placement would interfere with the compressor, I got the inlet at the top pass side and the outlert at the bottom driverside.
What kind of compressor do you have? Sanden makes a small one that will fit where the alternator is and then the alt moves up above it. March calls it their mid-mount. I think the 94-95 5.0's are like that.
Changing the radiator out might be a cheaper option. Unless you have one of those $700 radiators.
rbohm
6,698
550
204
tucson,az
Jul 13, 2007
  • Jul 13, 2007
move the compressor to the other side.
Z06killinSBF
457
McKinney, TX
Jul 13, 2007
  • Jul 13, 2007
Not sure the mounting bracket will work. It's a Vintage Air kit.
M
mustangman1974
463
  • Jul 18, 2007
go to kragen and they have a 90 deg radiator hose bend. I think its 30 bucks then you can run it parallel with the radiator in front of the compressor.
D
D.Hearne
11,730
south louisiana
Jul 18, 2007
  • Jul 18, 2007
I'd figure out a way to move it to the passenger side head too and then lower on the head. Sticks up way too high. Or use a longer hose and tie it down over the middle of the compressor housing. Better there than over the fan. Unless you fab a shroud to go between the fan and hose.
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
Engine Bleeding air in the heater core
  • keel
  • Apr 2, 2026
Fox 5.0 Mustang Tech Apr 23, 2026
limp
96 GT 4.6 w/ dirty spark plug well
  • Mustang Momma
  • Apr 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 9, 2026
LILCBRA
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
M
  • mnky99
  • Sep 5, 2025
mnky99
M
