Computer question
Harness points downward. IIRC Wes (who yanks these things out in 10 seconds) said he puts the puter in the cradle and then bolts up the harness afterwards. I havent tried this method yet.
HISSIN's right -- I've had good luck putting the PCM mostly in the bracket and then connecting the harness to it. With the harness on, it's tough to get that sucker into the bracket fully.
Good luck, be sure to disconnect your battery while you are moving wires around in there just case you knock anything loose on accident!
Wes
